Page 2 of 2
Posted: Fri Feb 29, 2008 12:23 am
If you attach the ground at the batteries , it would be wise to put a battery shut off switch in the battery box to terminate ground. this way you can kill the ground when not using to prevent unauthurized use and preserve the battery ground shuttoff keyswitch functions.
Breakers on winches are useless
24V winch
Posted: Fri Feb 29, 2008 6:07 am
by Buzz
Thanks Jim, I was planning on using the original cut off switch and I was planning to run the cables all the way back to the batteries.
I will assume your perspective on the breaker is that its very difficult to get the most out of the winch in tough situations if a breaker gets in the way?
Posted: Fri Feb 29, 2008 11:51 am
by M Wehrman
I took the control box off mine and mounted it under the glove box. It cleans up the front and minimizes the "unauthorized use" issue. It only takes a paperclip to operate the winch at the box..
Mark
24V winch
Posted: Fri Feb 29, 2008 7:38 pm
by Buzz
Got a call from WARN this evening. They do not recommend breakers.
24V winch
Posted: Fri Feb 29, 2008 7:56 pm
by Buzz
By the way, here is a picture of the winch bumper we made for my truck. We reinforced the bumperettes by welding 1/8 inch steel inside which converted them from C channel to box section. Then we built up the middle section. The floor plate the winch sits on extends through the front plate and is held by the pintle pin which will take most of the pulling loads.
If anyone is interested in knowing more I can put up some more pictures. My buddy Bob who did the work is thinking about making more or selling plans.
http://i33.photobucket.com/albums/d74/B ... Bumper.jpg
Posted: Mon Mar 03, 2008 1:22 am
by AK NIMROD
HERE IS A PHOTO OF THE HEAVY DUTY BUMPER MY SON MADE AND THE WINCH MOUNT. WINCH IS DETACHABLE AND CAN BE LOCKED IN PLACE
Posted: Mon Mar 03, 2008 8:45 am
by Erik712m
http://s177.photobucket.com/albums/w205 ... bumper.jpg[/img] Buzz good looking winch mount. I choose to have the bumper
http://s177.photobucket.com/albums/w205 ... bumper.jpg can some one tell me how to post pics again?
Posted: Mon Mar 03, 2008 11:21 am
by AK NIMROD
ERIK- in photobucket just click on choice below the picture that begins with img......bottom one IMAGE CODE that copies it then just paste it in the message.
Posted: Mon Mar 03, 2008 1:05 pm
by Erik712m
[img][img]
http://i177.photobucket.com/albums/w205 ... bumper.jpg[/img][/img] Thanks Aknimrod i have struggling with posting pics for some time. FYI Andre in Cal made this winch bumper he is a member of the forum
24V winch
Posted: Wed Mar 05, 2008 6:25 am
by Buzz
Thanks for the reminder on how to post pics
Posted: Sun Apr 06, 2008 4:03 pm
by Denis
Good day
Here is my take at putting a winch on my Pinz. I build the bumper and like Morris the controls are inside on the side of the right foot well.
On both sides, under the aluminium plates are small boxes to store shackles and small stuff.
Denis
Posted: Sun Apr 06, 2008 6:37 pm
by Jerbearyukon
Very nice Denis - you have put alot of thought and work into it.. Again I have to comment on the paint job - If nobody else has seen the work on the inside you should post it...I think it looooks GREAT
Jer Bear
Posted: Sun Apr 06, 2008 8:55 pm
by bernhard
Too clean
Posted: Sun Apr 06, 2008 11:05 pm
by VinceAtReal4x4s
Guys, geez, come on... those fairleads are WAY too clean and shiny.
Can't you find a Jeep to pull out?? At least a Kia? How about 3ft of mud to get stuck in?
