BTW they had already done some spring work in the past for a customer who wanted softer
Mike Nims has my other spring and is scearching the lowlands for other options.
TTFN,Mark
In my case, with the old tired springs the front of my 712 measured 13" from ground to bottom of differential; with heavier springs, I now have about 15". Remember, the factory specs are something like 13" ground clearance at full load, so if you are getting close to that empty you might need new springs. Or, do you find you bottom out often on the trails? (I did).How to tell for sure if the front springs need to be replaced?
