Posted: Thu May 31, 2007 8:29 pm
Greg
The seller obviously didn't know that much about TDs, as he has some.... ah, untruths. After reading the listing several more times, I wonder if he knows anything about it, or winged it because most people know even less. The vacuum power for the brakes and lockers comes from a mechanical pump off the engine. There is an electrical compressor for the air ride system, and I doubt that it ever worked. The only time mine ever came on was when I had 12 large 12v AGM batteries in the back, and that was for only a few seconds. The Swedish Pinzes also had modified springs to make up for all the weight they carried. Originally, the Pinz on ebay also besides having a Sepson hydraulic winch ( winch and mount about 330 lbs), had a "small" Hiab crane on the left rear panel. If you look at the pics of the ebay Pinz and The Pink Cow, you will notice how much clearance there is in the rear wheel wells, this is not normal, with stock springs 716s will ride level because the airsprings will automatically inflate or deflate, per the sensor on the right rear axle. A sitting 716 rear axle will have a negative camber when left overnight , as the air will bleed out, but will pump right back up when the ignition is turned on.
Dave Dunn
Dave Dunn
