RE: Dash Lights
Posted: Fri May 30, 2008 5:10 pm
I have used lamp #1819 for some spots that use the small 24 volt bayonet lamps and I like them since the are just a little bit longer, which makes them easier to put in an take out. Tip: a piece of rubber/plastic tubing that just can be pressed over the bulb will let you turn it to release it and pull it out easily
Now for the dash, I have converted to Superbright Leds, since they have a MUCH longer life than the incandescent bulbs and are a softer light rather than such a "point" light.
The removal and replacement of the warning panel lamps is a Pain,
so I don't want to take it out very often. I can buy them in the colors that I want in each indicator section, white, red, green, amber, blue and even in U.V.
Price - .98 to 1.98 depending on color
http://www.superbrightleds.com/BA9S6_specs.htm
They even have replacement LED bulbs for tail and turn lamps
Thomas E. - 712M
Sonora, CA
Thomas E. - 712M
Sonora, CA
