Page 2 of 3
Posted: Sun Jul 12, 2009 12:55 pm
by Erik712m
ABSOLUTSECURITY wrote:
Erik712m wrote:
texas pinzgauer wrote:How did you put that much mileage in over the course of a weekend driving a Pinzgauer?
three days. Not that hard when you're doing 3500 RPM had to keep the speed up to get a breeze. A/c unit is to big and drained my batteries once I get it all insulated i think i'll put in a A/c like mark has. Image
What kinda of AC are you using! Upgraded alternator?
G
16,000 btu, yes. Lots of other things were plugged in as well
FDLMFAO ? No idea what this means.
Posted: Sun Jul 12, 2009 1:05 pm
by ABSOLUTSECURITY
Erik712m wrote: three days. Not that hard when you're doing 3500 RPM had to keep the speed up to get a breeze. A/c unit is to big and drained my batteries once I get it all insulated i think i'll put in a A/c like mark has. Image
G
What kind of AC are you running? and how are you powering it?
110 vac AC with inverter (what size inverter) or 24 volt dc AC unit?
FDLMFAO = fell down laughing my f-ing ass off!!!!!!!!!
Glynn
Posted: Sun Jul 12, 2009 1:18 pm
by Erik712m
110v A/c. A/c can be seen behind my son Jake. Inverter is http://www.qualitekindustries.com/50wadctoacpo.html Really is to big Also never gave low voltage alarm My EFi Controller gave the low voltage alarm.
Posted: Sun Jul 12, 2009 1:45 pm
by EvanH
Erik,
Is that you on the right with the binkie?
Has the idea of using a small window-mount AC with a small genset been hashed out? You could mount the AC on the back, over the door. Lower center of gravity and more easily remove it in the off-season.
-Evan
Posted: Sun Jul 12, 2009 1:51 pm
by Erik712m
Some day's I wish!
Hadn't thought of that. not a lot of room in the back with the door opening taking up a lot of room.
Posted: Sun Jul 12, 2009 2:04 pm
by EvanH
Posted: Sun Jul 12, 2009 3:39 pm
by Erik712m
EvanH wrote:Image
If I had enough coffee cans I could make it ducted throughout the pinz. :)
Posted: Sun Jul 12, 2009 6:33 pm
by undysworld
A custom Continental. Must be Bad Bad Leroy Brown. Somehow I never imagined it like that...
Sorry, old reference.
Posted: Sun Jul 12, 2009 8:07 pm
by russ
I installed a Toyotomi portable AC in my Pinz when I first got it. It only drew 400 watts for 4000 BTU. It worked surprisingly well for camping and had its own adjustable timer for automatic shut off. I ran it on a 2000 watt 24 volt inverter. The inverter has a low voltage shutoff to insure I didn't get the batteries too low.
The problem I had was where I mounted it. It exhausted air out the side behind the driver's door. Unfortunately when driving down the highway at any speed over 30 the flat front of the Pinz causes a high pressure zone at exactly the point where the AC exhaust was. This made it useless except for slower off-road driving.
When I discovered deeper water challenges I took all that out. I still have it around for camping but uninstalled it from the Pinz. Because of this I never put in the second bank of batteries to be dedicated to the vehicle accessories, keeping the starting batteries isolated.
Posted: Sun Jul 12, 2009 9:46 pm
by rollingpinz
Hello
With enough duct-tape, that could be a Red Green project.
Eric P
Posted: Mon Jul 13, 2009 12:33 am
by ABSOLUTSECURITY
EvanH wrote:Image
Check out those taillights!!!!!!!!!
:shock: :lol: :shock:
LOL!
G
Posted: Mon Jul 13, 2009 5:50 pm
by Erik712m
rollingpinz wrote:Hello
Eric P
Starting to really like the show been watching it online pretty funny stuff.
I'm also getting pretty proficient with duct tape. :shock: Wife yells theres dust coming in I pull over pull out the tape threaten to use it as a muzzle and proceed to tape up areas.
If you look at the pics you can see tape n a few of the dust entry areas once I find them all i'll caulk it before it gets painted. :lol: :lol:
Russ, good to see you post been poking to see if you'd respon.
Posted: Mon Jul 13, 2009 11:32 pm
by russ
I'm just bummed I didn't incur the wrath of Vince :wink: I really need to try harder I guess. It must have been the LEDs.
Been watching Red Green for years, used to wear his suspenders and flannel shirt to work on Halloween.
Posted: Tue Jul 14, 2009 7:49 pm
by David Dunn
russ wrote:I'm just bummed I didn't incur the wrath of Vince :wink: I really need to try harder I guess.
If you feel left out, I can oblige ya and beat you up :wink:
Does ya want me to make a comment about your girl's friend pic you posted on MY glass thread? :P
Posted: Sun Aug 02, 2009 8:46 pm
by Erik712m
FWIW. I ended up using styrofoam on the roof. One inch thick.
