2 more efi kits
Posted: Sat Jan 02, 2010 12:19 pm
Hey Guys
Just to give you an update on the efi system I am running. I drove the 712 heavily modified pinzgauer fully loaded pulling a loaded trailer, with 3 guys from Burlington Ontario Canada - Clearwater beach florida, nonstop.
1300 plus miles of pinzgauer drone... We did this so we were sure the truck was setup properly and if anything was going to fail, it surely would in the first 1300 miles. The truck is headed to Haiti to be a mobile clinic in the mountains. We averaged about 9 miles per gallon, but that is with the truck at 4000 rpm or more the entire trip and the rubber we have installed is about an inch shorter then stock. The system ran great had to make a minor adjustment to the hall sensor in North Carolina, and adjust the belt for the air-conditioning. Otherwise the trip went well, took us 37 hours, with little to no stops on the way, except fuel. We used aircraft headsets so we could talk to each-other with out going deaf, and played tunes over the system as well. Had a couple of first time experiences like micro-waved Gatorade. ( just to keep warm) we do have 28000btu of air-conditioning, but that doesn't help when its 28f outside. The pinzgauer heater box did keep the cab at a balmy cab temp of 44f , we also used those open up and shake heat packs in our boots and pockets.(thanks for the recommendation Jim) Other then that the ride was very comfortable. Top speed down hill 66mph, slowest thru the mountians was 25mph, and on the flat we held a comfortable 55mph. Not to bad for undersized tires and a rolling weight at about 10000lbs. All in all very happy with the set up we are using, Every part of Jims kit bolts right up and the sds ecu seems to love it. We did make some last minute changes to our A/c compressor set up and the location of the coils. I also will not be using the engine temp sensor location we did this time, although it give a great base line for programming if your outdoor temperature never exceeds a 40 degree sweep. The problem is my hot reading on the sensor never got above 140 when it was 32 degrees outside, yet when we hit florida it did get to 180s with no temp change on the cylinder head temps. ( it was mounted on the fuel pump block off cover) Other then that we only used 1.5 quarts of oil, and it is so nice to just hit the starter no matter what temp, or altitude you are at and the blasted thing starts faster then my 2007 tundra. Sorry for writing a book, but just wanted to give some feed back. Any questions feel free to ask. Jeff
Will try post some photos later.
