clutch?
Ok tried shifting into gear at the tranny input shaft and am missing 1-4 gear. It clicks nice seams to go into gear but all I can shift into is 5th. So I might repost this as transmission problem. Its funny the last time I had a tranny go out it made all sorts of noise leading up to the failure.
Bernhard
1975 710K
2013 Tacoma TRD 4X4
1975 710K
2013 Tacoma TRD 4X4
Hi jim thanks for the reply... I was about to call you!! I already checked the linkage and the dogbone is on firm. Im thinking its in the tranny as 5th gear is 1:1 and bypasses the layshaft. Could something have broken off in the shift linkage causing it to only shift into 5th?
Bernhard
1975 710K
2013 Tacoma TRD 4X4
1975 710K
2013 Tacoma TRD 4X4
I have found the roll pin in the shift tower can ride up and limit movement.
Pull the floor plate and try to shift into gears at trans,
5 bolts or nuts hold the shift tower on.
Could also be a broken fork or fork pivot pin or stripped teeth on input gear. Pull the tower and look inside, it should be obvious.
Feel free to call if you need to.
