Page 2 of 2
Posted: Sun Jan 31, 2010 6:46 pm
by totaljoint
If you have a hi-lift jack, there is no simpler/cheaper way to retrieve your t-post:
http://www.gemplers.com/product/M1195/M ... ost-Puller
Posted: Sun Jan 31, 2010 6:48 pm
by Erik712m
That only works if you can see the tee post.
Posted: Sun Jan 31, 2010 6:50 pm
by David Dunn
Erik712m wrote:I've used a Tee post before worked good but I didn't retrieve it or my tow rope as it seemed pretty well buried.
And that is why you have an eye on it, so you can pull it out with the pintle as you go by.
Didn't your mother run a string through your mittens as a kid ? so you wouldn't lose them
Posted: Sun Jan 31, 2010 6:56 pm
by Erik712m
You know how it is. By the time you finally get out, you're so frustrated. you don't think about much. But going home were it's warm. And the pintle was one of the first things I removed. I know have a D-Ring back there as I have seen the need for one.
Posted: Sun Jan 31, 2010 7:02 pm
by David Dunn
Well it's the same with sand ladders, you tie a long rope from them to a rear tow point, so you don't have to stop momentum to pick them up if you're still in the soup.
Posted: Sun Jan 31, 2010 7:20 pm
by Erik712m
David Dunn wrote:Well it's the same with sand ladders, you tie a long rope from them to a rear tow point, so you don't have to stop momentum to pick them up if you're still in the soup.
Funny thing is Overland journal did a write up on sand ladders and I don't remember them giving that tip. Sand ladders are on the list just need to figure out mounting first.
Posted: Sun Jan 31, 2010 7:33 pm
by David Dunn
Mounts are my earlier links
pull Pal
Posted: Sun Jan 31, 2010 11:14 pm
It seems that having that second person to set the PP could be a bit of a problem when traveling alone. With a long lead winch control and a pulley with the line doubled for a bit more strength could it not be set and the winch controlled by just one.
As I write this it sounds like a bad idea. Just idle wondering. Now I have all sorts of scenarios running in my mind. All with me going to the emergency ward (if they find me).
Posted: Sun Jan 31, 2010 11:59 pm
by David Dunn
Doubling the line will only double the spooling in time , still no stronger than the anchor point. You'll still need to feed out enough line to insure the PP will dig in.
BBBBut, there are many wireless remotes on the market for winches now.... what the heck.... it's only money.
This thread is making me go nostalgic..... I remember that some people would make carpet sand ladders of 2 x 6 s by 12" long, tied together with carpet or rope with a space in between to allow the ladders to be rolled up. Laid flat, they would be up to 6' long. Some would drive a spike at the front to keep the ladder from being kicked out of place, and again would put a tether on them so they wouldn't have to stop and go dig in the soup to retreive them
Posted: Tue Feb 02, 2010 10:24 pm
by andy
Posted: Mon Jul 26, 2010 5:24 pm
by Jerbearyukon
I have one and wouldn't be without one up here....sorry in the delay on this subject. Some places we go there are NO TREES...only tundra and under that ICE.
Here's a pick of a place just like that with a BIG BOGG full of mud and PALLETS of all things...yes pallets. Somebody actually thought pallets would work...so if you decided to take a run at this hole WATCH OUT.
It's my buddy acting like the german narrator....I didn't charge at the hole cause there were pallets in there and I was only in 4 wheel drive but we hooked up the pull pal and it worked out fine.
Good place to test it anyway.
this is the end of the pull (about 40 feet across but it made it easy - think I would still be there if it wasn't for it) as I made it through...piece of cake with the pull pal.
this lake was so much fun and lots of Lakers and grayling
getting the gear out and belly boats blown up.
som emore of the road
FISH ON - friend found a canoe with a hole in it, but he fished out of it anyway hahahaha
Posted: Sun Aug 22, 2010 5:36 pm
by Skeej
thanks Dave, I very much appreciate the reference to old skool- and want to learn and apply that ethic, and the tip on sand ramps is worth it
