Page 2 of 2
Re: Sources for Hub Steps
Posted: Wed Mar 21, 2012 10:19 am
by texas pinzgauer
That step is low enough for even my 84 year old stepmother to use. As if I'd even let her get near my Pinzgauer
Posted: Wed Nov 18, 2015 11:48 am
by oilcan
I was thinking about making some hub steps - any advice on metal thickness to use so that there is enough clearance between the hub and the wheel?
thank you all!
Posted: Wed Nov 18, 2015 12:26 pm
by krick3tt
I made mine from a 1 1/2 inch floor flange with 1 piece of pipe. Then welded on a piece of expanded mesh for grip.
I used a 12 inch pipe nipple and cut it into two even pieces so there was threads on each end to screw into the flange. I drilled a hole (fits a Phillips screwdriver shaft) at the end to spin it off in the event I was going through very rocky areas. Total cost $12.
The floor flange can be sourced at your local hardware store (HD or Lowes for me) and it is the perfect thickness for a fit between the wheel and the drum.
Posted: Wed Nov 18, 2015 12:59 pm
by audiocontr
i wonder what would happen if i attached streamers to them???
Posted: Wed Nov 18, 2015 2:56 pm
by krick3tt
They would go round and round and get tangled up. Put the streamers on the door handles or the antennas.
...and then get some spinner hub caps for the wheels. Paint the wheels gold and the top red.
Posted: Sat Nov 21, 2015 11:30 am
by ako
oilcan wrote:I was thinking about making some hub steps - any advice on metal thickness to use so that there is enough clearance between the hub and the wheel?
thank you all!
You can get some play-doh and put it on the hub. Put the wheel back on and tighten the lug nuts.
Then remove again and measure the thickness of the play-doh.
Posted: Sat Nov 21, 2015 11:53 am
by krick3tt
...or you could use calipers or a micrometer for inside dimensions. I did not have play-doh at the time I made mine. Interesting idea though.
Posted: Sun Feb 02, 2020 10:30 pm
by newtopinz
Hi 4x4pinz,
I like the design of your entry step. Do you think it will work for the rear doors on a K? If so I am interested in getting a pair.
Kelvin
Posted: Wed Feb 05, 2020 9:18 pm
by 4x4Pinz
newtopinz Kelvin
If I recall the K does not have the same "lip" that the front doors have. The lip is required to hook the step on. My wife is still rockin her steps when she goes with me in the pinz.
