Page 2 of 2
Re: Where can I get rivnuts / nutcerts for the 712M rub rail
Posted: Wed May 25, 2011 9:52 pm
by Scooter
Here is what I used. The middle hex part has a thru hole and use a hardened washer on top. hold hex part in place and use rachet to compress nut. Works good if you only have a few of them to replace. I bought metric rivnuts from McMaster-Carr.
Scott
Posted: Wed May 25, 2011 9:57 pm
by 4x4Pinz
Posted: Wed Mar 14, 2012 2:47 pm
by berger
Scooter wrote:Here is what I used. The middle hex part has a thru hole and use a hardened washer on top. hold hex part in place and use rachet to compress nut. Works good if you only have a few of them to replace. I bought metric rivnuts from McMaster-Carr.
Hey Scott.
Which rivnut did you buy? I am looking at the following part:
M6x1.00 10.00 0.7-4.2 95105A183 9.08
Zinc-Plated Steel Open-End Knurled Rivet Nut M6X1.0 Internal Thread,
.7-4.2mm Material Thk
I assume I want the rivnut that only goes from .7-4.2mm material thickness?
Posted: Thu Mar 15, 2012 11:16 am
by berger
I have decided to go with 1/4-20 rivnuts for this, rather than the M6-1.0. I bought a 3-1 rivet gun which does 1/4"-20 rivnuts, but not M6. The two are identical as far as the hole required and the material thickness etc. This is the part number for the rivnuts from McMaster-Carr:
1/4"-20 25/64" 0.027"-0.165" 95105A143 9.08
Posted: Thu Mar 15, 2012 11:55 am
by David Dunn
Buy the right rivnuts... too many Pinzes have been repaired with "close" and the poor sap that owns it next is stuck with a repair bill that didn't have to be ( or the owner forgot what he did).
A rivnut isn't a big thing except you have a mix of bolts for the same thing, and they can get buggered by trying to force them "a little" into the wrong pitch thread, and end up replacing nutserts needlessly ( and enlarging the original hole)
Carbs are becoming henteeths because of parts being destroyed because of people putting SAE and sheetmetal screws where a metric belongs.
Remember, all Pinzes have a previous owner, and some of your problems could come from one of those repairs.... think of the next owner when you fix something.... I know, you'll never sell it
but you may move up some day to TD, and you'll never want to drive that old gasser again
Posted: Thu Mar 15, 2012 1:44 pm
by berger
David Dunn wrote:Buy the right rivnuts... too many Pinzes have been repaired with "close" and the poor sap that owns it next is stuck with a repair bill that didn't have to be ( or the owner forgot what he did).
Hey David.
Believe me, I agree with you, and I come from the land of metric!
I am not so concerned in this case simply because I am going to use Philips or Robertson (Canadian!) bolts, so I won't need an SAE tool in my kit....although I keep a complete set with me anyway...
Posted: Thu Mar 15, 2012 2:00 pm
by David Dunn
And in there lies the slip... first a single SAE... then another.. then a USS until finally you use a Wentworth bolt !
Posted: Thu Mar 15, 2012 3:01 pm
by berger
Posted: Thu Mar 15, 2012 3:23 pm
by David Dunn
Also, I like Robertson head bolts.... I use them when someone peeves me
Posted: Thu Mar 29, 2012 2:28 pm
by djw
Neat little rivnut tool along the same lines as the home made.
http://www.aircraftspruce.com/catalog/t ... uttool.php
Probably have to buy a hardened M6 cap screw for M size, but that seems to get good marks in the aviation community.
Posted: Thu Mar 29, 2012 6:20 pm
I use this one which works like a pop rivet tool for the rivnuts (as long as they are SAE as it does not have metric heads):
http://www.use-enco.com/CGI/INSRIT?PMAK ... TPG=INLMK3
Works pretty good so far.
Posted: Thu Mar 29, 2012 7:27 pm
I've found this plier type one to work well for me. I purchased the 4, 5 & 6mm mandrels to go along with it.
http://www.mcmaster.com/#rivet-nut-inst ... ls/=gvoijm
Posted: Fri Apr 13, 2012 5:28 pm
by Andre
check out Hanson rivet and supply co. out of Pacoima, Ca. largest selection of rivnuts Ive found to include sealed, aerospace, and comercial fastners.
www.hansonrivet.com
Posted: Fri Apr 13, 2012 7:35 pm
by djw
berger wrote:Scooter wrote:Here is what I used. The middle hex part has a thru hole and use a hardened washer on top. hold hex part in place and use rachet to compress nut. Works good if you only have a few of them to replace. I bought metric rivnuts from McMaster-Carr.
Hey Scott.
Fwiw, I found those 10mm rivnuts too big for the existing holes on my K. I used their SS 9mm M6 rivnuts instead and they were fine.
viewtopic.php?f=17&t=7083
