Re: Polymer Composite 24V electric heater
Posted: Sun Jul 06, 2014 3:12 pm
The stock heat exchanger works quite well if the hoses going to the cab are wrapped with insulation. Much of the heat is lost from the exchanger to the cab through the paper hoses.
I use my WeBasto (fueled from the petrol tank) on the coldest Colorado days till the engine reaches operating temps and then shutting off the WeBasto I use the stock vents to keep the cab warm (approx 65 deg)
while I travel. This is on the cold 20 deg days here. The insulation on the hoses is also wrapped with foil to retain the heat.
Often I will have to open the fresh air vent or a window if the cab gets too warm. I also use the blackout curtain in the winter to retain the heat in the cab. No one sits in the rear anyway.
Apparently, many folks want the additional heat of an aux heater and I understand that, but I find the stock exchanger works well for me, even in the CO winters.
I also use a cover on the grille intake to heat the engine a bit faster on the runs around town as the engine will not get to comfortable temps on drives with stop and go traffic of less than 25 miles.
There is enough air traveling around the engine (in the winter) from the bottom of the vehicle and it also reduces the amount of white foam that appears on the oil cap. If foam is showing on the
cap, it is also apparent in the valve covers, as I have discovered while adjusting the valves while the engine is cold.
