3/4ths Good ie missing
I had the same problem a while back but with the #2 cylinder. I too went with the Air - Fuel - Spark theory of solving the problem, with no joy. Someone on this forum suggested that I may have a vacuum leak; sure enough I had a leak at the head inlet seal. Put in a new gasket and everything was fine.
Grab the front carb and see if it wiggles.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
Carbs are nice and snug, I have taken to giving them a wiggle almost everytime I take the dogbox off. I'll try the brake clean trick though.
At this point I am on the edge of my mechanical abilities.
How do I check compression and if it is bad, how do I go about fixing it? Rings? Seems like a big driveway job to me!
'74 710M Wrecked/Rolled
"The Worm"
'76 712M
718 Turbo Diesel
"The Worm"
'76 712M
718 Turbo Diesel
Grab a compression gauge from Sears, remove spark plugs, unplug coil (so you dont shock yourself), screw in the gauge, open up the carbs all the way and crank it 5 times. Record the number on the gauge. Do this for all 4 cyls.
Put the plugs back in and start it up. Expect it to smoke from all the fuel you just pumped in.
There should be a lot of posts on the forum explaining how to do it.
If you find low compression in any cylinders, adjust the valves for that cylinder and test again.
At least 75% of trucks with a low cylinder that I have checked, had a tight exhaust or intake valve.
When the engine warms up, the miss gets worse due to metal expansion, resulting in less rocker arm clearance , and the valve not fully seating.
Pinzgauer Pete
I am glad to be of service...it is indeed a tough job to diagnose a problematic vehicle without actually seeing it, a series of tests could be done in a matter of minutes that would isolate the issue and make it easier to figure out when you have the vehicle in front of you. I give you credit for having the patience to try the different solutions offered, and arrive at the solution to your problem all the while learning valuable diagnostic skills to help in a quick resolution the next time a problem arises.
710M
710M
