Page 2 of 2
Re: Battery equalizer
Posted: Tue Feb 21, 2012 1:17 pm
by berger
krick3tt wrote:Berger,
I have installed a switch in the lead from the battery to the converter (per Jim) and have had no drainage issues.
I do remove the battery key when it is not running and I may save some things but, the direct connection to the
batteries would not be affected by the battery key in my case.
When I connected it, I did have a toggle switch from the 12V post of the EQ to my radio, but the 12V wire from the battery to the 12V post on the EQ was not switched. I was advised to run the ground from the main ground on the truck to the EQ ground and the 24V from the 24V wire at the master switch to the 24V post on the EQ. The 24V was deactivated by the master switch. I also used the proper gauge wire to span the distances. I think I read somewhere here that my not going directly to the batteries was most likely my problem.
This is the EQ I used and the instructions to go with it. If I use this on the Pinz, I will make sure it is right beside that batteries. I didn't have this option with the Iltis.
Posted: Tue Feb 21, 2012 3:31 pm
by audiocontr
interesting!
Posted: Tue Feb 21, 2012 4:31 pm
by berger
audiocontr wrote:interesting!
The EQ? I bought it on eBay for $100 new from a Farm store. I called a couple John Deere shops just to get an idea of what they cost...$600!
Posted: Tue Feb 21, 2012 6:10 pm
by David Dunn
Berger,
Unlike many disconnects, the 710/12 Pinz's disconnect switch is on the ground side. This means if you wire any chassis ground component directly to the batteries, you stand a very good chance of burning it up if you try to start the Pinz with the disconnect off.... Simply put, with the switch off , those little electrical bugs find the easiest way to complete a circuit and if it's through a circuit board to the chassis, the smoke genie appears.
For some odd reason, electronic devices just don't seem to handle the same amperage as a 2 gauge wire. :? :lol:
Posted: Tue Feb 21, 2012 9:59 pm
by berger
David Dunn wrote:Berger,
Thanks! I am definitely not an electrical guy. I think I may just lean towards 24v accessories and go from there. I know my GPS can handle 24v, it is just the iPhone I want hook ups for...
Posted: Tue Feb 21, 2012 11:49 pm
by David Dunn
For a simple charger, just wire in a small voltage reducer to a cigarette socket for a charger. Or one of our electronic wizards can tell you what resistor in line will do the same thing.
