Starter grinding
19D20
Re: Starter grinding
Post by 19D20 »
My starter started grinding a couple of weeks after replacing it with the reduction starter. I replaced the mount yesterday. It had started to split between the rubber and steel allowing it to flex (just a little). I've started it like 3 times and no more grind so far.
bonefish635
Post by bonefish635 »
I too managed to shear the mount right after replacing the stock starter with the gear reduction one. I suppose the greater turning speed is a product of greater torque, so the increased loading on the old rubber mount exposes weaknesses that the standard starter would have ignored.
Tony
1973 710K
2001 Landcruiser Amazon
2007 Range Rover Vogue (sold)
djw
Post by djw »
norcal pinz wrote:where can i get the "keeper" piece in the photo is there a part number for that ?
712.1.09.022.2 is the part I think.
Yes, that's it. SAV has it for $32.11. IIRC, you'll also need a couple of different mounting bolts if you use this plate, 09-01-5.1 & 09-01-10.1.
