Page 2 of 2
Re: Tools for spark plugs
Posted: Tue Feb 02, 2021 3:27 pm
by heinz
I´ve just found the tools in the parts list.
Item nr. 1 ist the spark plug socket.
![IMG_2252[1].JPG](./download/file.php?id=8664)
- IMG_2252[1].JPG (1.87 MiB) Viewed 4481 times
![IMG_2253[1].JPG](./download/file.php?id=8665)
- IMG_2253[1].JPG (1.98 MiB) Viewed 4481 times
Posted: Tue Feb 02, 2021 6:54 pm
by djw
#1 is the critical tool (length) that makes the process easy. Longer tools don't fit, shorter won't work. I don't think the originals are readily available, are they? I remember getting sort of a generic from SAV.
Posted: Wed Feb 03, 2021 1:35 pm
by heinz
I will have a look into my Pinz tool bag tomorrow (if I don´t forget) and take a picture of it, but I think to remember that my spark plug tool is not exactly the same as the one in the parts book. I think I have a similar tool and a pin to rotate the tool, but it works o.k.;
Posted: Wed Feb 03, 2021 3:15 pm
by ChickenPinz
It's pretty much the same tool that came with my motorcycle.
Posted: Wed Feb 03, 2021 5:37 pm
by djw
Yes, sort of the generic one I got from SAV, basic plug wrench with a pin. Probably 6" long if I go find it in the toolbox.
Posted: Fri Feb 05, 2021 2:21 pm
by heinz
Below is the spark plug spanner that came with my Pinz when I´ve got it from the Austrian Army and it works also on Rehab. Length = 6 1/2 inch.
- 710M Spark Plug Spanner 04078x.jpg (505.26 KiB) Viewed 4434 times
- 710M Spark Plug Spanner 04077x.jpg (287.11 KiB) Viewed 4434 times
Posted: Wed Apr 28, 2021 5:05 pm
by Fentonite
djw wrote: Mon Apr 23, 2012 8:55 pm
djw wrote:Can anyone post the size/mm of the spark plug and wire connector? None of the books seem to list it and I am not near the truck.
13/16 plug?
Wire connector = mm?
2. The 13/16 plug wrench
substitute is Briggs & Stratton Spark Plug Wrench 5402H that is a bit long but works just ok, better when you can get a 19mm rachetless socket wrench on the other end. It needs to be a hair thinner especially where it is near the valve covers, so I may take a grinder to the part at that point.
Thanks.
This thread just saved me a headache - THANKS! The Briggs and Stratton Plug Wrench worked great
