Page 2 of 2
Re: Another noise thread by a newbie....:)
Posted: Sat May 26, 2012 2:18 pm
by berger
Well, I was able to remove the drain bolt on the rear diff and I am happy to report there was plenty of fluid in there. Old fluid, but it was there
. Since the drain bolt was not rounded out, but over sized for the 10MM, I was able to tap in an 11MM hex and that worked like a charm. The plug is now shaped to accept the 11MM perfectly. I will change it out when I get my new plugs just to be safe. Now to drive it and see if the noise reappears....so far it hasn't.
Posted: Sun May 27, 2012 2:17 pm
by Thomas-E
Just thought I would give my 2 cents, be sure to use anti-sieze on the plugs, with the dissimilar
metals the need that extra protection to prevent galling the aluminium case.
Oh...you only need about 8 ft./lbs torque.
Scott (IE) also sell a new style plug.
Best wishes
Posted: Mon May 28, 2012 11:15 pm
by rmel
To add to this thread, and I am not sure this has any commonality with
berger's thread, but I also have a rather unusual noise, or better -- a
harmonic vibration. At a similar speed to berger, e.g. 90 KPH, there
is a rolling vibration, initially vibration free, then building up to a peak
shaking the rig, this repeats every 4-5 seconds. Yes, I have EX-1's,
but Scott at EI checked these out and in good shape. Brian at EI even
took his tires of his truck and tried them on my, same symptom, so
rim/balance doesn't seem to be a player here. This is just odd at this
frequency of 4 to 5 seconds, and very annoying -- I do like the gear
whining though. I also installed Jim's "Quietizer" on the tranny
mount -- no luck.
P.S. Berger, if your plug thread is stripped, I'd recommend Helicoil, I
used this on my 18mm-1.5mm O2 bung and it worked great -- tight
space on a Pinz header for this operation.
ron
I
Posted: Tue May 29, 2012 6:12 am
Ron,
Yours sounds like maybe an out of balance internal driveshaft. Try engaging the first locker at highway speeds on a straight road. If it goes away when locked, then your driveshaft needs repair.
Posted: Tue May 29, 2012 10:35 am
by rmel
Thanks, I'll give that a try, although all shafts had been balanced,
but all ideas are very much appreciated!
cheers,
