Page 2 of 2
Re: GPS Speedo
Posted: Tue May 12, 2015 12:54 pm
by Mr Zero
John L wrote:Cool find. But, it only operates off of 12v... I guess you hook it up to a converter or step down?
The Speedhut unit works like a charm. I installed the $10 DROK 3A 24v to 12v step-down converter below to achieve the required 12v.
Re: GPS Speedo
Posted: Tue May 12, 2015 2:40 pm
by John L
I'm sold! How did you make the install? It appears that our dash hole is 3 5/8 and this one is 3 3/8. Did you have any issues putting it in or making it stay in place? Did you need a spacer or have to make something to get it to fit correctly? Just curious. I'm thinking of ordering your set up. I especially like how you can customize the face plate. Pretty cool!
Re: GPS Speedo
Posted: Tue May 12, 2015 4:24 pm
by VinceAtReal4x4s
Very cool!
Re: GPS Speedo
Posted: Tue May 12, 2015 4:50 pm
by Mr Zero
John L wrote:How did you make the install? It appears that our dash hole is 3 5/8 and this one is 3 3/8. Did you have any issues putting it in or making it stay in place? Did you need a spacer or have to make something to get it to fit correctly?
The Speedhut unit is 84mm to our 86mm mounting hole. It felt like a perfect fit to me and didn't require any spacers to fit the space. There were a couple of small snaggles:
  • 1) The lip of the fiberglass shroud against which the dash panel fits comes up right to the back edge of the mounting hole. This needs to be trimmed to allow the speedometer mounting ring to tighten flush against the back of the dash panel.
    2) The knurls of the speedometer mounting ring don't quite clear the welded mounting nut for the steering column pad which sits just below the speedometer mounting hole. The easy fix here is to grind about half the length of the knurls on the mounting ring.
As for the wiring and the 24v to 12v downstep converter I'll use the speedometer diagram as a basis and upload a complete wiring diagram when I return from OX West next week.
Re: GPS Speedo
Posted: Tue May 12, 2015 4:54 pm
by Haf-e
They also offer a version with a domed front glass (less reflection of your face when you look in it) which uses a remotely mounted selection switch which could be installed in the hole where the original came out of...
http://www.speedhut.com/images/window/remote_button.jpg
They even offer built in turn signal indicators and high beam for those making up a custom dash.
Very nice...
Re: GPS Speedo
Posted: Mon Jun 01, 2015 5:11 pm
by Mr Zero
As promised here is the modified installation schematic using two 24v to 12v 3a/5a converters. PM me if image fails to display properly for you.
I used a 3a 24v to 12v converter similar to the one shown below. I purchased it from Amazon for ~$14.
Re: GPS Speedo
Posted: Mon Jun 01, 2015 7:14 pm
by Buzz
Thanks for posting this! One more item to add to my goodies list!
Re: GPS Speedo
Posted: Mon Aug 11, 2025 11:06 am
by rollingpinz
I know I'm late to this one, but I have two questions:
1. How did you cover the output for the speedo cable?
2. What did you do about the odometer reading?
Did you have to fill out a statement at the DMV, were you able to have the odometer set, or is there no odometer on the gauge at all?
Re: GPS Speedo
Posted: Thu Sep 04, 2025 8:41 pm
by Mr Zero
Apologies for the delayed reply...
rollingpinz wrote: Mon Aug 11, 2025 11:06 am 1. How did you cover the output for the speedo cable?
Used the end of a spare cable threaded in place to the front dif and capped.
rollingpinz wrote: Mon Aug 11, 2025 11:06 am 2. What did you do about the odometer reading?
Speedhut will set the mileage for you or you can program yourself. Setting it yourself is handy if your DMV has put a mileage restriction on your truck (as a classic, etc.). You can adjust the mileage as needed.
