Fuel Injection Patton style
HafWit
Re: Fuel Injection Patton style
Post by HafWit »
There was a 712m Pinzgauer over at Goatwerks when I picked up my Volvo that had the LEDs on it. Jim demonstrated them to me before I took off and drove 70 miles in the dark with the very dim lights on my Volvo. While there are better 24V incandescent lights than the ones mine has currently, I was intrigued by the LEDs in that they draw less power, are likely to last longer, and they are supposed to be more resistant to rock damage. Whether the plastic gets clouded over time and makes them less effective or not is an unknown to me. I also have powerful Golight turrets on the roof both front and rear that will give me extra off road coverage if I need it. These are of course illegal for highway use, but I figure new headlights (standard or LED) will be sufficient to solve my current issue.
Greg
HafWit
dokatd
Post by dokatd »
Update for an old thread, I installed the Patton parts on my Volvo awhile back and have driven it quite a bit. The system runs well if its tuned well. I ultimately had to do all the programming myself for multiple reasons, but the truck runs great. I still have a few items I will be working on (daily driver so not much time to polish the install) but will post some pics later. The install is brutally easy and the parts quality is good as well as Ricks service. I do recommend using your own computer and programming your own chip if you feel up to the task. I am more than happy to share my prom files to anyone with the understanding that it would only be a baseline and would still need to be tuned to your engine.
To sum up, its a great update to an old truck.
dokatd
Post by dokatd »
No real particular order to these, some are older than others.Please feel free to ask about any of it. One major note is the coaxial pipe fittings I made. I built a coax pipe fitting for vacuum that the map sensor and the IAC connect to. I also built a coax fuel return pipe. And by coax of course I mean Coaxial where one pipe extends through another. The fuel return is not as much of a coax as the Map/IAC is. The fuel one simply re-directs the return fuel down the fuel tank vent pipe rather than back up into the fuel cap. The Map/IAC one has a 4" or so smaller pipe running down the middle of the 90* elbow so that the map sensor reads the map from the intake manifold only and is not altered by the flow/pressure of the IAC.
I CAD drew all the white plastic parts for the computer and printed them on my printer. The bulge on the computer is to accommodate the universal chip and zif socket.
I still have a long way until it is the way I want it, I will be changing fittings and hoses over time once I feel comfortable with the configuration. Biggest change will be all stainless braided Teflon fuel hoses with better fittings. I really don't like the hardware store fittings but much of it was what was supplied in the original kit.
Got it running? Curious how you dialed in the MAP settings.
What did you pick for a O2 sensor/AFR instrumentation.
dokatd
Post by dokatd »
It has been running on the fuel injection for quite some time now, more specifically since October 3rd as I recall. You data log with the EFI computer so it allows you to see what the engine is doing. After you data log you can use the info you recorder to modify the fuel tables. I use protuner which gives you 3D fuel tables that you can work with. Programming the computer is very easy once you understand the fundamentals. Programming is not for everyone that's for sure as you can easily cause problems that could be anything from catastrophic to just really annoying.
I am running with a SDS ECU, high performance but poor data logging.
Spent time on a dyno to get dialed into the "zone", then I used my iPhone
to snap PIX's off the hand held controller for MAP, RPM, ADV, AFR to fine tune.
Huge PITA. Now my buddies at SDS have a USB port on the latest version of
the ECU to data log -- thinking about it, but these ain't cheap. BTW I am using a
PLXdevices wind-band AFR -- highly recommend these.
dokatd
Post by dokatd »
That SDS system is interesting. I like the redundant options that pulled over from experimental aircraft. Having the ability to data log in detail is a bonus for sure. I expect to regions the cam eventuall and port and polish the head so being able to log easily will be great. But if you have yours the way you want it then I wouldn't care to much about the upgraded unit with USB.
Klug
France
Post by Klug »
Hello.
I have a zillion questions!
8)
I'm currently talking with Rick about a kit for my Vattenfall (and Claes for parts and Martin/Tiagra for brakes).
Things are eventually moving after letting the truck in a barn for several years.
One of the question is the ability for the ECM to handle E85 (Ethanol) as well as E10/SP95 (standard gasoline here in France) without swapping the EEPROM.
Have you tried that?
Another question about one of your pics. I can see an air filter/breather not far from the coil. What is its purpose?
It can be seen on this pics: http://i25.photobucket.com/albums/c93/d ... 8BD61C.jpg and http://i25.photobucket.com/albums/c93/d ... D6022C.jpg
While I understand the way the coax MAP/IAC works, I don't really understand why you built it.
Isn't it possible to simply put the MAP and IAC in two different places (far enough one from the other)?
This one might sounds stupid: were you able to fit everything with the engine staying inside the truck?
Because it's "Bosch-based", the ignition cannot be controlled with the GM ECM.
Have you experienced issues because of that (knocking? stalling? other?)?
Which tire size are you able to use now?
Isn't the TPS too much of a hassle to setup?
That's quite all I think of right now...
Thanks a lot.
BTW: I love the printed bits for the ECM.
dokatd
Post by dokatd »
Klug wrote:Hello.
8)
I do not see a reason to believe it would not handle it just fine. But please do not quote me on that. A simple reprogram will address any issue though I am sure.
The filet is for the IAC valve. I may change it later as it is a bit noisy with the filter on it.
The coax fitting is to eliminate the need to drill into the manifold. The cast manifold has bosses where it is threaded, drilling elsewhere in the manifold, though not a big issue, is not always desirable and can lead to cracking or stripping etc. So I kept the manifold stock by building the coax fitting. And quite frankly it is much faster to build the coax than strip down the manifold to drill and tap it then hope to remove all the shavings before you start it back up.
Engine stays in place for sure, its an easy install.
I have a 123 ignition. It still cannot be controlled by the ECM though. I do not appear to have any ill effects. Rick can modify your stock alternator though if you want to have ignition control which is desirable in hindsight I think
I am running about a 35" tire. The truck runs well on them and easily keeps you up with traffic up to its practical top speeds.
TPS is easy enough to set, I would not say it is a hassle
Thanks a lot.
Klug
France
Post by Klug »
Rick said he could not modify a C303 genuine distributor (Bosch-based and not Lucas-based), I'll double check that with him.
I have to dig a bit more about that coax...
The IAC is not mandatory, as far as I remember (no AT nor AC).
What does it bring?
dokatd
Post by dokatd »
Klug wrote:Rick said he could not modify a C303 genuine distributor (Bosch-based and not Lucas-based), I'll double check that with him.
I do not recall, but I could have sworn he offered when i originally bought my kit.
What does it bring?
IAC is important while off-roading as it will reduce the occurrence of stalls. It also helps you maintain a more consistent idle especially when the engine is cold. I would not run fuel injection without it personally.
Klug
France
Post by Klug »
Rick confirmed he can not modify the Bosch distributor. So it'll be 123ignition too (already have mine, was working perfectly).
He also checked with the injection guys, they can add the real "flex fuel" feature to the harness.
The option uses a genuine GM flex-fuel sensor, hence its price ($450 for the option, the sensor itself is about $350).
A bit too expensive for me.
Is a standard EPROM burner OK?
dokatd
Post by dokatd »
Klug wrote: Is a standard EPROM burner OK?
I would get the Burner 2 from Moates. You will need a universal chip to reprogram unless you want to buy a UV eraser so you can use factory chips. I am also using a zif socket so I can swap chips easily and quickly.
Klug
France
Post by Klug »
Burner2 was on the short list (if no universal burner could be used).
With such an adaptor?
http://www.moates.net/gp1-package-gm-ad ... -p-41.html
Or that kind?
http://www.moates.net/gx-switching-adap ... -p-87.html
http://www.moates.net/g2x-tbitype-switc ... -p-86.html
dokatd
Post by dokatd »
Klug wrote:Burner2 was on the short list (if no universal burner could be used).
Or that kind?
This is what I ordered. But you need to be sure which computer they send you with your kit from Patton as things change in the later years.
1 x G2 Memory Adapter: 0.60" Leg Spacing (G2-0.60) = $30.00
1 x 'BURN2 Chip Programmer' (BURN2) = $85.00
1 x C2 SST 27SF512 Chip (C2) = $5.00
1 x S4 Aries 28-pin Low-Profile ZIF (S4) = $7.00
