710k running like crap
Re: 710k running like crap
Have you checked the timing? My distributor collar wasn't holding the dizzy on tight and it was shifting on me.
Sent from my iPhone
buzzz
Post by buzzz »
Hi Recon,
I had the same problem a while back with my 74m. After carb rebuild, fuel pump rebuild, new gas tank, Jim L advised checking the molex connection and bingo. I just cleaned it and it ran like new. would be worth a try.
Recon113
Post by Recon113 »
Where might one locate said molex connection?
Here you go:
3-7-12 04-51 PM - Version 2.jpg (42.24 KiB) Viewed 5928 times
Remove the 2 screws that hold the plug retaining strap in place and then gently wiggle and pull the plug out. A small wire brush, an old toothbrush or preferably a Dremel tool with a wire brush can be used to clean the contacts.
Also check the back side of the contacts; often that is corroded as well.
Recon113
Post by Recon113 »
I'm on it like white on rice....I was able to pull the connector and its a bit gnarly in there...I will start polishing it tomorrow
Thanks again everyone
Recon113
Post by Recon113 »
Well I cleaned the molex connection and a few choice swear words...I took it out for a test drive today and it ran like a champ! I will venture a bit farther some point this weekend. Thanks everyone.....beer and chili at my house! I appreciate all the help....thanks buzzz
buzzz
Post by buzzz »
Happy that it worked for you. I wish I had asked before I did all those things to my 710m. I Now check the molex every few months just to be safe.
totaljoint
Post by totaljoint »
The molex connector seems to be the mother-in-law of the Pinzgauer world.....aging and prone to failure, the cause for so many problems.
Since it comes up often in posts, and is commonly unknown to new owners, I nominate the above picture for the technical section.
Recon113
Post by Recon113 »
Maybe along with the picture a short or maybe long explanation as to what this connector connects and does and how it might affect everything else
That information is already posted in the old archive section complete with pictures and re route for power output wire 8) .
It takes a little searching, but it's there.
M Wehrman
Post by M Wehrman »
Sooooo Jim,you could have just described the process... :? OH! :idea: It's that give a man a fish and eats once,teach him how to fish...Blah,blah... :lol: :lol: Did you get the Haffy dizzy pics I sent? Pic might have sucked..
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
blackstack
Post by blackstack »
I have the same symptoms described by recon113. I initially thought it was a fuel problem as the vehicle was idle for several months..I thought water in the fuel..So in addittion to all the things suggested to recon I also changed the fuel filter and drained the fuel tank.....Unfortunately I did not experience a remarkable recovery from cleaning the molex connection ....i am searching for the explanation of the molex function ..but aside from that ,I am stumped.....anybody know of a mechanic familiar with the Pinz in the Seattle area?
That was my big issue when I lived up there. Could not find anyone 'familiar' with the pinz mechanics to work on it.
Had to come to Denver.
