Page 2 of 5
Re: Wheel Bearing failure noise
Posted: Tue Aug 27, 2013 12:17 pm
Hard to see from the first pic, but it looks as if there is NO lock piece under the bolt heads. If true, I'd assume PO had upgraded to LocTite on the bolts.
See no. 11 here:
http://www.pinzgauer.com/parts.php?cat= ... view=04-10
It is not used in the upgrade.
Posted: Tue Aug 27, 2013 12:50 pm
by berger
michaelh712 wrote:Berger,
Purchase an inexpensive digital thermometer with a lazer sight (like from Harbour Freight here in the states). Its an invaluable tool as has been suggested in several boards. After driving, check the temp of each hub. If there is a big imbalance, the highest temp may be adjusted too tight or the very lowest one too loose. In addition,d checking the head temps or exhaust headers can identify which cylinder may not be producing.
Thx!
One item I have been thinking of getting for a while.
Posted: Tue Aug 27, 2013 12:51 pm
by berger
undysworld wrote:Hard to see from the first pic, but it looks as if there is NO lock piece under the bolt heads. If true, I'd assume PO had upgraded to LocTite on the bolts.
See no. 11 here:
Excellent!
Definitely no lock washers.
Posted: Tue Aug 27, 2013 6:17 pm
by berger
Took the opposite drive off and I am happy to say all looks well here too.
- ImageUploadedByTapatalk1377645105.464853.jpg (172.98 KiB) Viewed 7538 times
- ImageUploadedByTapatalk1377645118.261536.jpg (178.33 KiB) Viewed 7538 times
Since I had a slight leak in both hubs,I am debating on doing the seals. I am confused about one thing. Jurgen's web page on the subject mentioned not to press out the hub because you might break the backing plate. In the EI video, Scott presses it out. What is the best way to go?
Sent from my Mobile
Posted: Tue Aug 27, 2013 8:46 pm
IIRC, I used a puller for both the gear and the drive flange. This is the puller I got from Harbor Trash (Sorry Vince
) but I had to modify the ends of the arms to fit into the notch in the gear. Then I made up a frame to mount the puller section onto the bolt holes in the brake backing plate, and was able to push it straight out. The frame is only 1x1 tube stock with some angle channel. Note that the shaft is slightly offset from the middle 4 bolt holes and center the drive hole accordingly on the 1x1. If you need pics, let me know.
http://www.harborfreight.com/14-piece-g ... 30305.html
Posted: Wed Aug 28, 2013 6:34 pm
by berger
Thanks to Paul's direction, I picked up a two-leg puller from Princess Auto....Canadian version of your Harbour Freight. I had to grind down the feet somewhat, but the puller pulled the gear off without any issues. One benefit of buying from China is you know their bolts are Metric!! I used the bed liner on my pickup's tailgate to hold the lugs in place while I removed the bolts.
- ImageUploadedByTapatalk1377732557.364855.jpg (140.69 KiB) Viewed 7494 times
- ImageUploadedByTapatalk1377732567.795727.jpg (139 KiB) Viewed 7494 times
I noticed that the socket bolts were 8.8, so I will replace them with 10.9.
- ImageUploadedByTapatalk1377732638.631774.jpg (143.77 KiB) Viewed 7494 times
Pulling the gear didn't take that much effort...
- ImageUploadedByTapatalk1377732717.373024.jpg (131.01 KiB) Viewed 7494 times
- ImageUploadedByTapatalk1377732734.561231.jpg (149.76 KiB) Viewed 7494 times
I did notice marks on the back plate....are these normal??
I am pretty certain this same puller, with the right metric bolts, can pull the back plate off. I will get those tomorrow.
Sent from my Mobile
Posted: Wed Aug 28, 2013 8:48 pm
Good pics Derek. That's about what my modified puller legs look like too. Well done! For a cheap puller, this really works quite well.
Posted: Wed Aug 28, 2013 9:36 pm
by berger
undysworld wrote:Good pics Derek. That's about what my modified puller legs look like too. Well done! For a cheap puller, this really works quite well.
Thanks.
I think I hijacked my own thread, so I am going to compile a seal fix "how to." There aren't any decent pics out there anymore of the whole procedure and the steps leave a lot to be desired. Scott's video is good, but a little fast and the delayed audio is weird!!
Sent from my Mobile
Posted: Thu Aug 29, 2013 1:42 pm
by djw
Thanks for taking the time to document and take pics of your work. Both for this and the stuff you've done in the past. Very helpful.
Posted: Thu Aug 29, 2013 2:53 pm
by berger
DJW....My pleasure!
I picked up some M10x130x1.25 bolts and nuts today. I had it in my head that the holes in the back plate were threaded!! DOH!
Anyway, they worked well and the back ate pulled off. I only needed grip strength to pull it off.
(Pics from my iPhone)
- ImageUploadedByTapatalk1377805676.829488.jpg (155.72 KiB) Viewed 7445 times
- ImageUploadedByTapatalk1377805689.001042.jpg (137.56 KiB) Viewed 7445 times
Looks like I have the older 60mm spacer ring seal on the PS (haven't pulled the DS side yet). I am not sure about the bluey oil...mine is yellow...
- ImageUploadedByTapatalk1377805845.821233.jpg (171.51 KiB) Viewed 7445 times
In Scott's video, I see him using a chisel to remove the ring....mine was not tight to the base of the shaft and I pulled it off with my fingers. Could this explain the leak? The o-ring looked fine.
- ImageUploadedByTapatalk1377805935.585610.jpg (159.49 KiB) Viewed 7445 times
- ImageUploadedByTapatalk1377805949.111254.jpg (170.89 KiB) Viewed 7445 times
Sent from my Mobile
Posted: Thu Aug 29, 2013 2:57 pm
by berger
I have the newer 55mm rings, SKF flange seal and o-ring from SAV ( had them for some time now) ready to go, but now I need to scrounge up some good snap ring pliers.
- ImageUploadedByTapatalk1377806137.833228.jpg (165.19 KiB) Viewed 7444 times
I noticed some rusty marks on the spacer rings...is this okay? They have been in there sealed packaging wrapped in waxy paper until now...
- ImageUploadedByTapatalk1377806216.310940.jpg (145.09 KiB) Viewed 7444 times
Anyway, once I get the snap ring off, I will be able to get at the bearing and ultimately the flange seal.
Sent from my Mobile
Posted: Fri Aug 30, 2013 9:57 am
by Stekay
Hey Berger, I'm sure you're anxious to get back up & running, but have you given any thought to finding alternative seals that would allow you to use synthetic gear oil in the hubs. Has anyone else? I'm thinking thats the direction I'd be going if I'm faced with hub disassembly.
Posted: Fri Aug 30, 2013 10:04 am
I found it interesting that 3 of your 5 retainer bolts were allen socket head vs hex head. When I ordered them from SAV recently for a repair/upgrade it showed all 5 were hex head and that's what I got. I wonder why a previous owner/mechanic would have used socket head - any thoughts?
Posted: Fri Aug 30, 2013 10:40 am
Just a guess. People use what they have on hand, rather than take time to order or fetch the proper part.
Often the client does not know or care as long as it works when done by a shop.
Posted: Fri Aug 30, 2013 11:29 am
by berger
Stekay wrote:Hey Berger, I'm sure you're anxious to get back up & running, but have you given any thought to finding alternative seals that would allow you to use synthetic gear oil in the hubs. Has anyone else? I'm thinking thats the direction I'd be going if I'm faced with hub disassembly.
I didn't know the seal would dictate what kind of oil I could use..... :?: I did read someone mention in an earlier post not to use KOK seals. The ones SAV sent are SKF.
I am happy to stay with dino oil, just because I buy it by the barrell and use it everywhere. Easier than one brand/type here, and one in another.
