the pinz rims are designed for nuts with a conical seat; ford rims have sightly larger holes, and a flat seat.
some folks in germany modified existing nuts ; i had bespoke ones made.
Albert
======================== My Pinz has NEVER been with any army
Please try the spare tire out on the Pinz and take a couple of pictures - I've seen the rims come up occasionally for sale as take-offs and I think as the number of these vans increase in the USA we will soon have a source of replacement rims.
Also - I thought the Pinzgauer lug nut seats were "ball" type and not conical? Would make modifying them to work with the original nuts much trickier...
There also are aluminum ones as well - but are pretty ugly in my opinion...
Great idea to have a spare set of rims with other tires mounted. I have a second set of rims for my town car with studded snow tires for winter. Rather than switch the tires on the rims I switch the entire set for snow/ice conditions. The price would be an asset.
The rims are standard 16 inch size - only they are somewhat narrow (6.5 inches I think?) and don't have a "safety bead" so its a bit easy for the tire to pop off the rim at low tire pressure and side loads (especially on the front). Some tires are listed as being designed for a minimum of 7 inch rims - but that isn't actually a problem with the slightly narrow pinz rims.
I think the best/maximum tire that works well is 255/85-16 but some people have used 285/75-16 which have the same overall diameter but are wider. They are heavy and with the swing axles the wider size doesn't work so well.
If you want real hardcore off-road tires there is a bias ply super swamper by interco which is taller and narrower (9x34) that looks very good - just don't use them on the highway.
Michelin makes a 8.25/100-16 tire which is almost 35 inches - they are used on some of the diesel pinzgauers and look great on them. Very hard to find although I have seem some listed on Canadian military surplus sites as apparently they are used on their G-wagons.
Disc Brake Conversion Kits for 710 and 712 Pinzgauers www.klugewerks.com
