Page 3 of 3
electronic speedo
Posted: Mon Feb 25, 2008 11:18 am
OK, back to the topic...The speedo has given up the ghost. Totally stopped working, not just retesting over and over. Connections are tight and the light works. I'm stumped. Thinking of replacing the original one that I removed.
I may have offended the Pinz spirits by installing non original parts...hope not.
Morris
Posted: Mon Feb 25, 2008 11:45 am
by mjnims
We just fixed one this past weekend that only wanted to register when trying to start the truck, other than that it was dead. I hooked up power from a known and tested good source. We found that it worked fine after that. If you have not yet ran a single temporary power source to the speedo I would do that first. This will make sure all connectors are in good shape. It only takes a moment and the speedo should do the test.
Sure saved us a lot of time tracking down problems.
Posted: Mon Feb 25, 2008 10:54 pm
My VDO electronic speedo works great, but as of last week the odometer/trip meter is blank. Has anyone seen this before?
Posted: Tue Feb 26, 2008 7:17 am
by andy
Mims, so what are you saying, that the connections in the target vehicle were bad or loose? So far this thread doesn't appear to much of an endorsement for the electronic speedos.
Posted: Tue Feb 26, 2008 7:19 am
by andy
Oops! Nims instead of Mims.
Posted: Tue Feb 26, 2008 8:19 am
by mjnims
The connection at the source was broken. The connector appeared to look good but when we took it apart it had broken. Once we got a good power source (tied to the ignition switch) the speedo works fine again. Both the units in my Pinzgauers work fine so far and the wife is much happier with the MPH listing in stead of the KPH.
Posted: Tue Feb 26, 2008 8:52 am
by andy
Thanks Mike. I've been considering one for a long time because mine quit reading accurately a long time ago. That's why I use the GPS in town. I can't even get the angle piece to break free from my speedo just to see if a direct connect would help. The upside is that it practically reads in mph instead of kph now.
