As I said before, there are several reasons for this. One big reason is that it's better to exceed expectations than to disappoint. Another is that neither Herbert nor myself or "forum" types. I prefer email based lists, and if I do post it's most likely on the pinzgauer mailing list.Erik712m wrote: Alan, Hi that is all we have to go on as you guy's never post.
What follows is detailed EFI tech talk.... this is not a sales pitch. We are not selling to individuals. But if you want some specifics, here they are.
And that's why you should not give any credence to rumors.Erik712m wrote: From the rumor mill north of you I hear Herbert was having problem's with his controller? False?
1) We have not seen any controller related issues. Period.
2) When designing & implementing a new system that totally replaces both fuel and ignition, you can run into snags. Especially when interfacing to an OEM ignition system. Things like the "sense" of the trigger coil, etc. But you get past those with troubleshooting. Herbert ran into an issue like that on the first start of the first pinz. I came up, and we had it running & idling reliably after a couple hours of troubleshooting. That is the only "problem" we have seen, it was 18 months ago, and it had nothing to do with controllers. So much for the rumor mill!
3) Anyone planning on doing their own EFI/Ignition will run into that type of issue if you are fabbing your own harness, etc. This is one of the reasons we decided that a plug & play wiring harness is not optional. Just too many subtle things, not just to get it running, but to have a reliable system in conditions that we put our pinz's in. Example: You can burn out ignition modules if mis-wired. You can get hard starts, but running if you have your injectors cross wired. Low fuel pressure due to cobbled together plumbing can create intermitant problems.
While you chase a basic wiring issue you'll see fouled plugs, flooded engines, low battery voltage, etc from failed start attempts that can take a simple problem and mask it to look like something else. Controllers are rarely the issue, it's the basics that get you! Example: Incorrect Trigger coil polarity can allow a vehicle to start & run, but timing will be off or intermittent. Spikes on sensor wiring due to ignition/sensor wire routing can cause mysterious behavior only under certain conditions.
By providing all components, with tested wiring harness complete with OEM connectors installed, we eliminate those variables. So you bypass the learning curve.
Never forget that the pinz is a high vibration, wet, hot environment compared to many vehicles. They see conditions your average "import tuner" Camry EFI system never sees. Which leads to.....
4) Controllers are the least critical part of the system to get a vehicle running, even running well. Yeah, controller features allow you to do some things that are useful. Some are easier to setup/tune than others, etc. But they are not a limiting factor if they have comparable basic features.
What does make a difference in long term reliability/usability is packaging. This means size, form factor, cabling, water tightness, etc.
Our 1st gen controller works great. Vehicle runs great. Absolutely reliable day to day. But we felt the packaging/form factor could be improved on, especially for bone stock pinz's with 24v systems. And for certain customers, expectations are higher.
Our 2nd gen controller and wiring harness really gave us what we wanted in terms of form factor/simplicity and is about as close to OEM level engineering as you can get in an aftermarket controller. Like the rest of the pinz, you can now wash the inside of the cab with a hose and not worry about the controller. Everything from how the wires are routed, bundled, and wrapped has been refined for long term reliability.
This also means no external relays, fuse boxes, etc to fail. And to find a place to mount, etc.
Along the way we rolled in:
- Close loop idle & fast start control. This was a huge win, and creates one of the largest drivability improvements we have seen. Being able to turn the key & drive off in any temperature from far below freezing to over 100 is critical for some customers, and we've achieved that.
But the real advantage came in offroad usage... a combination of tuning & air management have yielded a system that is very difficult to bog down/stall. Yes, you can force a stall, but we can now idle up hills, boulders, etc that would have stalled conventional EFI and a carb would never allow.
One of our key tests is to idle up a steep hill in a higher gear, to the point that even closed loop idle cannot compensate. Then roll in throttle with the engine bogged to 500-600 rpm. We see immediate throttle response, no spit, lag, backfire, delay. It just goes, smoothly and without drama. This is not something you can do with tuning on a dyno, and is hard to do at all without certain controller features that your typical aftermarket EFI for the sports market does not even think about.
- cold start... To get "turn the key & drive off" performance we adjust/control 7 different parameters during cold starts: fast idle air, spark, 5 different mixture parameters, and open/closed loop. You can get one to start & warm up with only a couple of these, and that's the approach most aftermarket EFI utilizes. But the pinz really responds well to adjusting these params based on both ambient air & engine temp.
So everything from Priming shot to spark is adjusted based on temperature and what point the engine is in during cold start. This is not just basic VE map & warmup tuning. Because we absolutely control the idle speed at any given point in the warmup cycle we can fine tune the mixture/timing to match. That's OEM level tuning, and was our objective. Our test is simple, crank the pinz and drive off. It has to respond smoothly independent of temperature. Lot's of tuning, none of which can be done in the lab/dyno. And very hard to do with open loop fast idle during extreme cold starts.
- This pinz engine is a unique beast...... as several have found out, assumptions about other engines, even air-cooled vw's do not play out the same on a pinz. I've rewritten portions of the controller firmware to account for unique pinz behavior. This is not just changing settings like all EFI systems are capable, instead, it's changing core controller behavior & control.
As one example... the engine temps on a pinz vary widely. You can have a fully warmed up engine see cyl head temps drop below the "warmup" threshold on extremely cold days. Likewise, there are times the pinz wants a very rich mixture, other times not. Idle, cruise, and under load you want different behavior.
We've taken Herbert's decades of experience with the pinz engine and refined the system to incorporate these nuances. Every thing from where you take your engine temperature to when to operate closed loop vs open makes a difference.
So when folks ask about photo's, etc, it's simply not an area we are interested in right now. That will come in time. Next will probably be a video showing hillclimb idle response & control. We've spent our time dealing with subtleties that are required for our customer base. We've had drivable EFI pinz's that performed well for over a year. But the advances we've made in the last few months are in the details.
I will say that Herbert is pretty sensitive to folks reverse engineering things that we have developed. He's had some bad experiences, which I understand & respect. So anyone is welcome to drive either the 2.7l or stock swiss pinz with EFI. But you won't see detailed photo's for a while and even then only if released as a kit to individuals.
Before anyone asks about availability: Herbert is uncompromising in terms of his expectations, and will not release a kit to individuals until he is completely satisfied that it can be installed by an individual and run right out of the box.
You can get the system right now if you really want it.... Herbert's personal pinz is for sale and has this system installed. The "pickle".... 2.7l, high speed tranny, disk brakes, custom short wheelbase, etc. It's a killer ride, and probably the hottest pinz around. I personally have been in this pinz at 80-85 mph during road tuning, measured by GPS.
Again, not a sales pitch. If someone wants pinz EFI now, there are other options. Especially if willing to cobble something together, and go through the learning curve. I enjoy that type of thing! But I like driving pinz's better!
Have fun,
Alan
