Page 3 of 4
Posted: Fri Feb 19, 2010 5:11 pm
by karoja
from Shropshire UK to Kuala Lumpur Malaysia
That must have cost some dear money, as the body requires almost a complete 20' Container to ship. Hope you filled the body with goodies as well.
Great to have this thread. I managed to do all my conversion without using any type of trailer lifts (not planning on talkin the camper off in the future), and the camper is still separate from the chassis.
Posted: Fri Feb 19, 2010 5:20 pm
by fesm_ndt
karoja wrote:from Shropshire UK to Kuala Lumpur Malaysia
Cost is always a problem with people affected by Pinzgauer madness
One of those snap decisions, when money was in my pocket and although I like the soft top, I do not want a car full of dust again when travelling.
Posted: Tue Feb 23, 2010 1:53 am
by fesm_ndt
ABSOLUTSECURITY wrote:
Dewalt 18 volt circular saw and a sharp blade to cut the straight lines!
Glynn
Seeing the box is floating over my way.
Can you please elaborate on the saw?? i.e. what blade type, diameter etc as I am going to have to find an equivalent over here.
Posted: Wed Feb 24, 2010 2:19 pm
by ABSOLUTSECURITY
Any regular circular saw and a finer tooth carbide tipped blade meant of aluminum or plastic is what i used to cut the fiberglass foam box.
Posted: Wed Feb 24, 2010 11:47 pm
by fesm_ndt
ABSOLUTSECURITY wrote:Any regular circular saw and a finer tooth carbide tipped blade meant of aluminum or plastic is what i used to cut the fiberglass foam box.
Cheers for that. I'll have to try the hardware store here next week. The problem here will be the people in the shop know nothing, mind you that is becoming a trend everywhere.
Posted: Wed Mar 10, 2010 10:14 am
by fesm_ndt
anyone got a picture of the cable plug connecting to the box?
I have a 2 pin plug but before I mod my cut off power switch plate I want to know I got the correct bit
hmm
Posted: Wed Mar 10, 2010 9:00 pm
by Picasso
not sure what you want a pic of. Two pins + and - with 4 wires in the cable. two + and two for - and sometimes another small wire that was is for illumination but have not seen it connected.
http://shup.com/Shup/294392/110210185851.png
Re: hmm
Posted: Wed Mar 17, 2010 10:45 am
by fesm_ndt
Picasso wrote:not sure what you want a pic of. Two pins + and - with 4 wires in the cable. two + and two for - and sometimes another small wire that was is for illumination but have not seen it connected.
Thanks for that, it looks like I may have the correct vehicle mounted plug to fit then.
Here's hoping as the box arrives over the weekend, with a few days in customs. Hopefully it will still be in one piece.
Posted: Sun Mar 28, 2010 4:23 am
by fesm_ndt
Well my box arrived
full of goodies I bought plus missile testing equipment
Posted: Sun Mar 28, 2010 1:13 pm
by ABSOLUTSECURITY
PICTURES!!!!!!!!!!!!!!!!!!!!!
Time to start cutting! PICTURES!!!!!!!!!!!!!!!!
Glynn
Posted: Sun Mar 28, 2010 7:14 pm
by fesm_ndt
I have to get the back off my M and the fit it up but seems only need to lop 700mm off the back
Full of cupboards which I need to remove/move
I have never been able to get a photo to link in here
http://hmvf.co.uk/forumvb/showthread.ph ... ild/page13
hmm
Posted: Tue Mar 30, 2010 6:02 pm
by Picasso
Try and use a free service like stashbox or shup.com The pics hosted on the other site need us to have a login for the forum.
So from what I understand your going to shorten the box? I'm a little unsure what the cuts your going to make are for.
Posted: Tue Mar 30, 2010 8:13 pm
by fesm_ndt
hmm
Posted: Wed Mar 31, 2010 7:57 pm
by Picasso
Are you going to take from the middle? The rear has a metal frame Do you know the maker of your box? I have a pinz here with that same box with side doors.
Posted: Wed Mar 31, 2010 8:14 pm
by fesm_ndt
Yep the ID plate is inside..... Can't recall what wriien now.
Will cut the 700mm off the rear as was sent a site where someone did the same thing, well to an ambulance box
So I think de-rivet the rear end and see how the rear door frame is held to the top and bottom rails.
Also have to move the lifting lug points and the roofrack mounting points so going to be interesting
Well and remove the rear interior fittings
Lucky I got a spare tub to mount it on and do the fiddling about first
