I decided to put in double Grote "jeep" style tail lights on each side (e-bay, new@ 9.00/ea) and used 63 LED 1157 bulbs:
http://cgi.ebay.com/ebaymotors/2x-63-LE ... ccessories
for the brake/turn and the same in 1156 white for the backups:
I have plenty of light back there now on brake/turn:
and with back-ups:
Only problem is that when I use the right turn signal, the right is blinking smart and bright, but the left also has a dim blink (180 degrees out of sync) and visa versa.
Not noticable when the driving lights are on, just when the turn signal is used alone.
I assume the LED's are sensitive to low amperage and that I must have a leak from one side to the other. Is this an issue with my new
Hella electronic flasher?
