Re: L.E.D. Headlights installed today!!!!
Posted: Thu Jul 19, 2012 12:17 am
I put a set of these in this evening, thanks Pete. Installation was a snap, and Pete included some of the connectors Miles referenced.
I wanted to see what the difference was like so I put the left one in and did some comparisons to the H4 in the right. The fit is absolutely perfect with no alignment or fit issues. They pop right in.
My Pinz is one of the Austrian refurbs that got H4 headlights in the upgrade. I do not know for sure but I think most of the Swiss Pinzgauers have a different, possibly older headlight than the H4 style. I have always liked H4 bulbs, particularly the sharp cut-off beam pattern. In my case the original headlights were wired with a standard H4 plug and also had two additional spade connectors for the "pilot light/parking light" feature inside the H4 shell where there is a secondary "glow" light/terminals in the H4 reflector below the actual H4 bulb. The wiring provides current to this tiny bulb whenever the headlight switch is 'on' and the ignition is 'off'. It was kind of a cool nightlight feature to have, I don't know if the Swiss versions have this, and I will have to experiment to see what the Trucklite does if you give it a couple of volts (considering a step-down resistor of some kind to fake a pilot light).
I soldered up the pigtails with a male H4 plug on one end and the military bullet connectors on the other so that it can be returned as stock with no need to cut or splice the original harness. I put the left LED headlight in and took some pics. The Trucklite bulbs "bug out" an inch more than the H4 but even in the daylight, the color difference is dramatic from the yellow H4 headlights. The lights are icy white.
Compared to the H4 it is a tough call. I like them but I also like the H4, particularly the beam pattern. The edge goes to the LED.
I took some lousy phone pics both facing the truck low/hi, the beam pattern against the garage, low/high, and a few driving pics.
Happy to answer any questions. I think the H4 high beam throws more light. Otherwise the LED is preferable, but it is close and the white color fools you a bit.
I swapped out the right H4 after the test and, as you might expect, the entire bulb unit was very hot, almost too hot to hold. The LED light was barely warm.
By eyeball, the LED lights are distinctive and rather odd looking (eye-catching) when viewed from another vehicle. If you are not dead in front of the headlight, the low beam appears to be lit mostly from the upper half, which it in fact is. This is one of the reasons I was interested in changing to LEDs since the Pinz is hard for others to see at night and I think there was a risk of someone not seeing me and pulling out or turning across me. Anything to make me stand out in traffic is good and running LED's in the daytime in traffic is easier to justify. The weird factor I'm guessing I'll get one of the local, bored gendarmes pulling me over to look at the weird lights.
So I suspect these are a much more dramatic upgrade to any pre-H4 Pinz. I like the LEDs best and will keep the H4's in my spares for now.
Thanks again Pete for everything.
