Page 3 of 3
Re: Transfer cased just popped out of Hi range into neutral
Posted: Fri Jun 22, 2012 7:10 pm
by David Dunn
Jer
I would still think that the ball and socket were stiff and didn't pivot correctly... unlike a body part, that cable wouldn't shrink in the cold
Posted: Fri Jun 22, 2012 7:48 pm
by Jerbearyukon
Hey I am not giving up on her.....it was the plan anway..I have her rigged up for the north but in costa rica I will die in there without AC. Be nice in that country to be ablw=e to take the roof off to and get the fresh air.
Dave...the socket was moving pretty easily so maybe it was something else.....I have been running it disconnected for a whole day all over the place and nothing nada....
I will try the cable tomorrow and check the length out and if its not bang on then I will just lengthen it.
Jer
Posted: Fri Jun 22, 2012 8:08 pm
by David Dunn
Jer
If you want a softtop, just remove the hardtop on your K... that's what I did on my 716. Not a tough thing on a 710 and Scott makes tops for them. Even a standard 710M top will fit... just can't use the rear side doors when the top's down. I liked the front facing rear passenger's seats
Posted: Fri Jun 22, 2012 9:13 pm
by Jerbearyukon
hmmm...maybe that's the way to go....we will see
thanks
Jer
Posted: Sat Jun 23, 2012 5:06 am
by crcpinz
It's only $400 for a new one:
http://www.pinzgauer.com/showdetails.ph ... 101243210/
I rebuilt mine for $150.
Glad it's the cable.
Posted: Sat Jun 23, 2012 10:23 am
by David Dunn
Unless the cable end is bad or frayed, he won't need a cable, just an adjustment
Posted: Sat Jun 23, 2012 11:49 am
by crcpinz
Yes, sorry, rereading I understand now that Jerry meant the transfer case and not the shift cable when he stated $1200 or so for the rebuild.
