Re: Locker rebuild??
Posted: Tue Sep 18, 2012 3:16 pm
Morris, guys, you were incredibly accurate on the diagnosis and the method of removing the knobs. When I removed the knobs with a spanner wrench and a slight tap from a hammer, the knobs popped off and one of the metal spacers did run off into never never land. I also broke both part 21 and 27 (as expected). I've ordered replacements and am waiting on them to come in.
Since you guys nailed the problem on the head before I even opened the cover plate, pray tell the best way of replacing the two parts I popped. (Middle lever and popped the cast metal below the lever and the one next to it that engages the locker) I see a bolt on the passenger side which seems to hold the levers in place and the cast pieces I'm replacing seem to slide on a shaft. Also, how do I get the piece of the linkage that connects to the lever off of the broken part and on to the replacement part?
As always, any help you can provde is greatly appreciated.
John
John
