Page 3 of 3
Re: Front Shock bolts
Posted: Fri Jun 14, 2013 8:42 pm
berger wrote:I finly got everything together tonight....spent to long in the patio....
I noticed the front wheels are much more rod-eyed then before....I am assuming this because of the shocks??
As soon as you roll forward (or backwards) the wheels will return to normal angles.
Posted: Fri Jun 14, 2013 9:19 pm
by berger
Thanks Ed!
Love taking advice from a fellow foil head!!
Sent from my Mobile
Posted: Fri Jun 14, 2013 9:28 pm
If you have just jacked it up and lowered it down and not driven it a bit then the wheels aren't where they will be after a drive.
I notice the same thing when I adjust the brakes.
edit: I was posting when Edzz was and we said the same thing.
Posted: Sat Jun 15, 2013 10:22 pm
by berger
Thanks guys!!
Just wanted to report in on the shocks.....WOW! What a difference!
Not knowing any better, I just assumed the truck rode like it did because it was a 40 year old military vehicle. These new shocks have made the ride SOOO much better.
Sent from my Mobile
Posted: Fri Aug 23, 2013 1:25 pm
by berger
krick3tt wrote:If you are torn...put two on and leave two off..... see which lasts. Report back to the forum. You can be our tester.
UPDATE
I have not gone through any water at all since installing them....well, nothing that would have gone past the centres of the wheels and even that is a stretch, but I have been in some heavy rain. I decided to lift a rear boot to check, and sure enough water drained out. I am not sure how long it sat in there, but that was enough to convince me. All of the shock boots have been removed.
