Re: Pinzi SSI
Posted: Wed Oct 09, 2013 9:17 pm
Andre is correct, there is a lead to run your tachometer. The module is programmed to signal once with every crankshaft revolution. The VDO in my Pinz has to be re-set, using the switches on the back. Right now it shows about 50% accuracy.
Scott is also right about water prevention, it can't hurt. The module under normal conditions is waterproof, but probably not underwater. I spoke at length with the manufacturer today, and he stated that the module has worked when full of water, but that's a temporary condition. He could make something to fit over the module to make it watertight for submersion, but it would be an add-on for individual buyers. Probably not cheap, either. Since it rarely rains where I live I haven't had a chance to drive in the rain. What I can do is post a video of water running over the module from a hose with the engine running. Then take the cap off and see it any water got in. No customer has had rain issues with any of the other units this company makes, and some are on Harleys- fully exposed. Putting a module in a bucket of water for a while is another test option, the bottom of the stem would have to be sealed first.
There is no way to make the 4500 light go on with this system. You will know when the engine stops revving higher that it is working.
Having 4 advance curve modes is a go. This way Pinzgauers using lower octane fuel can run OK, as well as those at high altitudes. The way it will work is position #1 is the most aggressive for normal street/highway. Then the next 3 settings will lessen the advance for heavy loads, low octane, low speeds off-road, high altitude, or any combination thereof. #4 will be the least aggressive in advance. The wiring is such that if there is a failure (loose connection, cut wire, etc), the timing will go towards #4 instead of advancing to #1. Grounding the 2 advance curve wires puts the curve at #1. Ungrounding 1 wire goes to #2, re-grounding that wire and ungrounding the other goes to #3, ungrounding both goes to #4. Grounding merely completes a circuit, it is not a return path for measureable current. A rotary switch for changing curves is included, as well as a bracket. It mounts using the screw holes that hold the windshield washer bottle.
All brackets are powder coated 1/8" aluminum, in 6014 olive drab. All mounting bolts, screws, ties, and electrical connectors are included.
