Page 4 of 6
Re: 718 Rebuild
Posted: Tue Aug 19, 2014 9:27 am
by fesm_ndt
G'day Peter sexy gear shifter cover. With it being thicker will it all work ok? It's been nagging me
Re: 718 Rebuild
Posted: Tue Oct 07, 2014 4:17 pm
by Profpinz
I don't see a problem Mike, because the complete shifter assembly is under the cover which doesn't interact directly with the operation of the mechanism however if there is problem I'm sure there will be a work around
Re: 718 Rebuild
Posted: Wed Dec 03, 2014 6:59 am
by Profpinz
Re: 718 Rebuild
Posted: Wed Dec 03, 2014 8:55 am
Is the outside of the transfer case painted or raw?
Re: 718 Rebuild
Posted: Wed Dec 03, 2014 10:26 am
Also what is the inside coated with, and why is it coated? Excellent work, as we have come to expect from the Professor!
Re: 718 Rebuild
Posted: Wed Dec 03, 2014 9:07 pm
by Profpinz
G'Day Dan and Jim,
Standard factory Pinzgauers have raw alloy castings and whilst the look good initially I've found that over the years, despite high pressure washing etc, they just become ingrain with dirt/mud/grime etc and whilst one wouldn't worry about it in normal circumstances (I haven't on my 712) I thought this time I might look for a solution/fix to keep them looking reasonable.
Some Pinzgauers owner paint the alloy castings which helps to keep them in good aesthetic condition, but I like the look of the bead blasted finish as it looks somewhat like the original factory finish, so I opted to use a POR15 two pack clear designed for such applications......I bead blast then spray them straight away to preserve the "just cast" look and hopefully keep them in nice nick for a while.
As regards the interior painting, again I use a product called Glyptal which is specially developed for this use as it:
1/. Stops weeping/permeating through the castings.
2/. Helps with oil drainage.
3/. Seals any stray material/media after blasting etc.
4/. On cast steel components such as the drop boxes it stops internal rusting from vapour/condensation.
https://www.youtube.com/watch?v=77CKFnRHA3c
http://www.eastwood.com/glyptal-red-brush-on-1-qt.html
Re: 718 Rebuild
Posted: Thu Dec 04, 2014 9:20 am
Thanks for the reply - I like the look with the clear coat
I was thinking about using this on my Hafi cast parts- similar but I have never used this product before (new) so have no reference vs POR15 which I have used (black paint only)
http://www.eastwood.com/exoarmour.html
Sorry to go off topic in your thread
Re: 718 Rebuild
Posted: Fri Dec 05, 2014 4:47 am
by Profpinz
I use GLISTEN PC, a POR15 product.
http://www.ppcco.com.au/por11.html
Re: 718 Rebuild
Posted: Fri Dec 05, 2014 9:55 am
by Andre
I will definitely be making use of this product.
Re: 718 Rebuild
Posted: Thu Apr 09, 2015 8:03 am
by Profpinz
Re: 718 Rebuild
Posted: Thu Apr 09, 2015 3:09 pm
by Haf-e
Very nice work!
Any idea why they used the 6 cylinder VW diesel motor in the Pinzgauers instead of a much more available Mercedes 5 cylinder diesel - especially since they were building the G-wagens with them in the same facilities? Always wondered...
Re: 718 Rebuild
Posted: Thu Apr 09, 2015 10:20 pm
by Profpinz
The TD's are a strange mix of VW and Mercedes parts......eg, VW/Audi brake calipers, Mercedes door handles, both VW and Merc "special" cable ties etc
I understand the 716/718 was originally designed/intended to have a Steyr Monoblock diesel fitted (M14 or equiv) however as Steyr Puch was also involved with VW at the time developing the Syncro 4WD system there may have been some monetary/political reasons for "trading" products/services.
I'm not a big fan of the Merc 5 cylinder motor as fitted in the G's (I once joked with the Managing Director of Merc Benz Australia that my Haflinger could outrun a 300 G), but I love the Steyr Monoblock's and understand a few factory prototypes were fitted with these motors.....also the Pinzgauer III developed by AT was to have had a Steyr motor fitted. It's a popular military choice in many specialist vehicles.
Re: 718 Rebuild
Posted: Thu Apr 09, 2015 10:50 pm
by Haf-e
Yes - that is what I suspected... Also, didn't the Noriker also use this same engine? Since they were competing with the Mercedes Unimogs with that platform I guess it made more sense to use a VW engine for it.
A Steyr Monoblock engine would be great - I see them at the big marine shows here usually. Very nice engines.
Re: 718 Rebuild
Posted: Fri Apr 10, 2015 12:15 am
by ako
Wow. Incredible attention to detail. Great thread. Like many others I seem to missed this in the diesel section.
Might have to drop in on my next trip 'home' for a look in person
Re: 718 Rebuild
Posted: Fri Apr 10, 2015 6:50 am
by Profpinz
Haf-e: Yes, you are right, the Noriker did have the same 2.4 motor..........I'd forgotten about that!
Basically the Noriker is 4X4 version of the VW LT, and the 2.4, 6 cylinder motor was originally designed for that vehicle.
Ako: If you are in Melbourne feel free to drop by.....Just drop me an email and we'll set it up.
