SOS WI DOT Cancels ALL Pinz Titles!
EuroPinz
Post by EuroPinz »
Here is the answer I have received:
Bei dieser Angelegenheit können wir den Pinzgauerbesitzern im Bundesstaat Wisconsin leider nicht weiter helfen.
Die Pinzgauer wurden nicht für den US-Markt entwickelt, daher entsprechen sie auch nicht den FMVSS-Vorschriften.
Sollten die Pinzgauer jedoch älter als 25 Jahre sein, gibt es eventuell die Möglichkeit, die Fahrzeuge trotzdem für den Amerikanischen Straßenverkehr (siehe Punkt 1 im Anhang) zuzulassen.
Diesbezüglich bitte Sie, den Pinzgauerbesitzern mitzuteilen, dass sie sich direkt an die NHTSA (National Highway Traffic Safety Administration) bzw. an den Importeur wenden.
Punkt 1 aus der Declaration:
The vehicle is 25 or more years old or the equipment item was manufactured on a date when no applicable Federal Motor Vehicle Safety Standard or Theft Prevention Standard was in effect.
Date of manufacture:_____________________[591.5(i)]
Regards
Jacques
Erik712m
Post by Erik712m »
They are the new missionaries and they have laws instead of armies to force us to adopt their religion
You couldn't be more right. You also should be watching the profiters to follow.
andy
Post by andy »
I found this over on the Yahoo group in files: It is long, but there are several mentions in it about civilian use. I tried to highlight a pertinent part.
Automobil Revue
Reprint from No 25-1971
Pinzgauer- the newest mechanical horse in our army
Transport vehicle with 1 ton loading capacity- All-wheel-drive- Aircooled 90 or 87 h.p. petrol engine- 100 km/h road speed
The army will soon take large-scale deliveries of a new cross-country vehicle from the Austrian Steyr-Daimler-Puch works. The model is called “Pinzgauer" - which has the same origins as the Haflinger. Both names were well-known as Austrian farm horses of sturdy build, high endurance and good mountain-going abilities. The following technical data indicate that these horse-like characteristics have been incorporated in the new cross-country vehicle. Like the Haflinger, the Pinzgauer finds its way to the public through deliveries to the army. The original design of the new model differs from conventional army vehicles and in view of the intended introduction to the civilian market at a later date it is of particular interest to note that this vehicle can be driven with a group A driving licence.
The design of the Pinzgauer
The "Pinzgauer" is a further development of the "Haflinger", well-known for its cross-country driving ability. Its basic design principles have been proven in practical use. The “Pinzgauer" is constructed on the same lines, having the following characteristics:
Centre frame chassis with independent axles
All-wheel drive with selective front wheel drive, identical front and rear axle drives; selective differential locks
Air cooled petrol engine
Fully synchronised multispeed gearbox and selective additional gearbox
Steering in front of engine and loading platform support.
Air-cooled petrol engine
For general use, even a purpose-designed cross-country vehicle must have a sufficiently fast road speed. 100 km/h is acceptable but requires at least an 85 h.p. engine for such a vehicle. The need for a robust engine needing little maintenance calls for air cooling because an air-cooled engine fulfils this requirement better than a water-cooled type. Since no suitable engine was in the production range or available from other sources, an air-cooled, four-cylinder in-line engine has been developed to suit the special needs of the Pinzgauer.
It is a horizontal, four-cylinder, 2,5 litre in-line engine. The bore ist 92 mm and the stroke 94 mm. The maximum output of 90 h. p. (or 87 h. p.) at 4000 rpm is achieved with a compression ratio of 7,8 : 1 - high grade petrol (or 7,5 : 1 - low grade petrol). Maximum torque of 18,5 mkp is at 2000 rpm. The engine has finned separate cylinders and finned aluminium cylinder heads with semi-spherical combustion chambers and overhead valves. The valves are controlled by pushrods and rocker arms. The engine casing is light alloy, holding the five-bearing crankshaft. Lubrication is by gear pumps of the suction and pressure type. The suction pump delivers oil from the front of the engine sump to the oil container and the pressure pump sucks the oil from the oil container and feeds the crankshaft bearings and cylinder heads, through drilled lubricating channels passing through a thermostatically-controlled oil cooler and an inline fine mesh oil filter. Carburation is by two inverted carburettors which are not position sensitive and have a choke arrangement. The combustion air is cleaned in a micro air filter. Electric power supply is by a 28 V, 650 W alternator. An axial fan provides engine cooling. The well-dimensioned, single-disc clutch is hydraulically operated.
Standard and additional gearboxes
The specified top speed and the need for low speed call for a wide gear ratio (approx: 1 : 10). For comfortable control, a five-speed gearbox is used with a sufficiently big ratio (5 : 33) to prevent the need to select the five-speed additional gearbox in normal road or cross country use. The gear ratio of the additional gearbox in road and cross country use is 1,92 in order to achieve a total ratio of 10.6. All gears, including supplementary gears, but excluding reverse, are synchronised.
This gear arrangement permits a top road speed of 100 km/h as well as continuous low speed at full engine power of 4 km/h.
The engine-gearbox unit is fitted in the conventional direction below the front seats, immediately behind the front axle and in the highest possible position. To reduce engine space, the cylinder axis is at an angle. This position protects the engine as far as possible against damage or dirt. A short, exposed drive shaft connects the flexibly mounted engine-gearbox unit to the auxiliary gearbox. The auxiliary gearbox housing, together with the central frame tube and both axle housings, provides a strong, distortion-free backbone. An auxiliary drive can be fitted to the supplementary gearbox. This drive is on the far side of the engine and points forward. The five-speed gearbox provides for different auxiliary drive speeds, and, if necessary, the drive can be selected during driving.
Transmission
The two or three axle (6 X 6) configurations are of the jointless crossshaft type with two pairs of bevel gears, each wheel being driven by one pair.
A further normal gear train is fitted to the wheel hubs. This design permits increased ground clearance. The homo Kinetic drive joints of the front axle are completely enclosed. External damage is not possible. These two joints are the only transmission joints between supplementary gearbox and wheels. All drive shafts are completely protected inside the central tube and the half axles.
The front wheel drive is selective. The differentials of the rear axles can be manually locked separately or together with the front axle. The front wheel drive and the differential lock can be operated while driving without interruption of power transmission by depressing the clutch or reducing acceleration.
Selection is by driver-operated manual levers hydraulically controlling the units without auxiliary power. Brake fluid is used for the hydraulically operated brakes. All bores of operating cylinders are chromium plated to prevent rust.
Wheel suspension, shock absorbers and steering
As already mentioned, the axle housings are a rigid part of the central frame tubes (one tube for 4 X 4, one additional tube for 6 X 6 between the rear axles) and are the backbone of the chassis.
In front of the rear axle (centre axle on 6 X 6) is the two speed supplementary gearbox.
Suspension is by frictionless coil spring having cross sections and varying pitch to cope with increasing loads. The springs are complemented by rubber sleeves. This guarantees correct suspension over the full vehicle loading range. Well dimensioned telescopic shock absorbers ensure stability. To obtain then necessary width to load standard pallets (800 mm wide) between the rear wheels, the four-wheel models (4 X 4) have two smaller diameter coil springs fitted for each rear wheel. These springs again have a progressive characteristic and are fitted in conjunction with rubber sleeves.
The six-wheel models (6 X 6) have a balance type leaf spring on each vehicle side between the two rear wheels. These springs are of the parabolic type for best shock absorbtion and the maximum upward spring movement is limited by rubber sleeves.
Steering is of the rack and pinion type using split control rods ensuring correct steering movement regardless of suspension travel, The control rods are fitted with maintenance-free universal joints. The front-wheel drive parallel joints are fitted inside the front axle and are lubricated from the central lubrication system.
Servo brakes
The brake drums have a diameter of 285 mm and a lining width of 76mm. The brakes are scaled against dirt. Front wheel brakes are of the duplex type, rear wheel brakes are duo servo (equally efficient in either direction). Operation is hydraulically assisted by a vacuum brake assisting unit. A two circuit system is used. One circuit controls the front wheels, the other the rear wheels.
The hand-brake acts mechanically on the rear axle drive shaft and to all wheels if front wheel drive is engaged. The actual brakes are completely sealed disc types remaining fully efficient even after driving through water.
Simple Maintenance
The Pinzgauer is designed on a module system to simplify maintenance, repair and spare parts stockholdings The drive shaft components with jointed cross axles are the same, so are the gear wheels, wheel flanges, bearings and brake drums as well as the covers with brake carriers.
No greasing points are allocated to the suspension. The coil-springs press on to hardened half-spherical shells resting on spherical-beaded bolts without lubrication. The centres of the rear springs of the Pinzgauer 6 X 6 rest on rubber blocks (silentbloc), the leaves press on to rubber mountings resting on the same type of spherical headed bolts as fitted to the front springs of the Pinzgauer 4 X 4.
Bodywork
The bodywork rests on the chassis with seven rubber mountings, two on the cross member of the front centre member, two on the rear crossmember and one below the rear door on the trailer coupling flange. To prevent cross movement, the bodywork is further secured by a rod from the front foot recess to the chassis. The rigid tubular chassis protects the bodywork from twisting or damage due to shocks from the wheels on very rough country.
The front steering gives the best view for the driver and permits a large loading area for this relatively small vehicle. The full loading floor is available to transport goods. To carry personnel, seats can be fitted to the floor and legroom is available in the recesses provided. The module system is also used for the bodywork. Only two types of bodywork are intended: the first is a three-door type with two conventional and one rear door for cabin access from the loading platform. The floor of the loading platform is recessed between the wheels to a width of 825 mm to tak6 standard pallets. The floor extends on both sides full length above the wheels.
The second type is a five-door model. The two additional doors are on both sides between front and rear wheels. The floor area between these doors is at the same level as the centre loading space. Various additional body structures can be fitted to both types. The body is self-supporting and can be removed from the chassis in one piece. After removing the driver and front passenger seat, a large cover can be hinged up to give easy access to the engine.
The Pinzgauer in our army
The Austrian-made Pinzgauer will be with our troops in the next few months. This is a new cross-country vehicle as part of the necessary replacement of army machinery.
Of course, the authorities do not intend to extend the present range of military vehicles. The EMD (Defence Ministry) has for years pursued a clear policy of fulfilling a multitude of army requirements with a minimum of vehicle types.
The introduction of the Pinzgauer is a further step in the miltary vehicle replacement programme. The new vehicle replaces older types which are no longer economical to repair.
The Pinzgauer is by design a typical multi-purpose vehicle. It will replace a number of out-of-date army vehicles. These are mainly the Dodge weapon carriers and commando cars purchased 25 years ago as American war-surplus material, and since then in constant hard use. In a few years, the almost 20-year-old Mowog will need replacing. The Pinzgauer will also be the intended replacement. Therefore, two vehicle types are replaced by one.
There are further long-term possibilities of using the Pinzgauer as a replacement. The one-ton Unimog will have to be changed in due course.
Another problem has been the large number of commanding officers who at present have just a jeep with hardly any room for weapons and equipment apart from the four seats. And access to the rear seats is not very practical.
If a CO intends to use a driver, a radio operator, a runner and some advisers, the Jeep is no longer suitable. The Pinzgauer is the answer because there is room for nine passengers, excluding driver, and space for material. More equipment can be loaded if there are fewer passengers. With the Pinzgauer, a CO receives a very mobile but small one-ton vehicle hardly larger than a Land Rover but with good cross-country ability because of the basic design: all four wheels have cross-country characteristics. Incidentally, the Pinzgauer is manufactured by our EFTA partner, Austria.
To complete the story, it must be said that such a design is not a recent development but originates from the designer Ledwinka Senior, who has constructed such vehicles in the thirties with Tatra in Czechoslovakia. Ledwinka moved to Austria in 1948 and found new challenges at Steyr. His son is today chief engineer of Steyr and ensures the further success of the original design of his late father.
The 6 X 6 version of the Pinzgauer will soon follow. Engine, transmission, suspension, etc., are the same as on the 4 X 4. The additional rear axle assembly permits a 500/o extension of the load floor giving room for 12 people (loading capacity approx 1,5 ton). The total weight of the Pinzgauer 6 X 6 is limited to 3.5 tons to permit driving by holders of normal passenger car driving licences. R. V.
Production release from an Austrian point of view
Messrs Steyr-Dalmler-Puch, registered in Vienna, main plants in Steyr and Graz and subsidiary plants troughout Austria, are known abroad mainly as commercial vehicle producers. In 1959, the company introduced a light cross-country vehicle, the Haflinger, which was a big success in the military and civilian sector, although the production was relatively small as is normal with such special purpose vehicles. This vehicle is widely used in the Swiss army as a cross-country transporter.
The firm introduced the Pinzgauer on 17 May 1971 in Graz. As for the Haflinger, the name Pinzgauer originates from a famous breed of Austrian cart horses. The day was a new cornerstone for the Graz works.'Production of cross-country vehicles is extended and future demands are sure. it is intended to produce approx 10,000 Pinzgauers over the next five years. The total production of the next few months will be supplied to the Swiss army. The management states that the Pinzgauer will only be available for civilian use in 1972. The small Haflinger will still be produced in the new plant in Graz together with the large scale production of the Pinzgauer.
The history of the Pinzgauer goes back six years. Market research indicated sufficient demand for large-scale production of such vehicles. Possible customers, among them the group for military supplies in Switzerland, received prototypes at an early stage of development. Steyr-Puch points out today that this vehicle has been designed from the marketing viewpoint. For instance, a first picture of the Pinzgauer with radio equipment was published in the ,AR" No 24 in May 1968, introducing the vehicles of the armament programme.
The economical importance of the Pinzgauer production decision must have been influenced by the Swiss army contract. It is regarded by the SteyrPuch plants as strengthening the image originating with the Haflinger and also the fact that this is a true group product. All Austrian Steyr plants helped by supplying parts or assemblies to finalise the product. Involved were, Apart from the Graz plant, the Vienna plants in Simmering - the previous Austrian Saurer Works - the plants in Steyr being the original works for armaments, ball-bearings and heavy goods vehicles, and the plant in Hittenberg/Kromag. Production of the Pinzgauer has also been influenced by other Austrian suppliers like the Semperit tyre producer which developed the 245-16 universal tyre for road and country specially for the Pinzgauer.
The Steyr works are rightly proud to have scored again with the Pinzgauer, the design of which is based on experience from the Haflinger and which has been accepted immediately abroad. EWS
A bar F
The buck STARTS here
www.deerleaseservices.com
Hi RollingPinz, Sorry if you viewed my post as below-the-belt. Indeed states do have the authority to make their own rules regarding registration of vehicles, it isn't a federal issue. However, federal importation laws dictate that the EPA and DOT issues are EXEMPTED for vehicles over 25 yrs. old (as I expect we are all aware already). I don't want my truck "grandfathered" in.
I am appealing to my elected reps, as it appears the Wis DMV has acted on their own. I'm merely asking for the same road rights in Wisconsin that everyone else gets.
If you don't think that legislation which begins in one state can't encourage other states, well, you're welcome to your opinion. I differ.
I just got my first response from Senator Ellis' office. They're still waiting for a reply from DMV. I just heard from Leg. Rep. Pope-Roberts. She promises a reply ASAP. My email to Sen. Erpenbach went out this morning.
rollingpinz
Post by rollingpinz »
Hello
Sorry. I was only making a swift reference to the speach given to boxers before the fight. It was just a jab (get it?) at humor after the depressing truths about humanity.
Eric P
Pinzgear
Post by Pinzgear »
It kills me--you can drive a friggin' John Deer tractor 5mph on the highways in Wisconsin, but you can't drive a road-worthy truck simply because it's "military". What a joke!
Sean
Scooter
Post by Scooter »
I called my Senator Kedzie's office today. He is aware of the issue and my e-mail. He has gotten a few other letters as well. He will "get back to me" shortly. I also sent an e-mail to rep. Scott Newcomer. My wife works with his brother and he said that he would talk to Scott and have him call me. So still a big ZERO from me.
We have to keep up the pressure and phone calls otherwise it will be ignored. Keep it up.
Scooter
Sorry Eric, I should have caught that one. That's the (one of) trouble with the internet, you just can't see the wink and grin.
Okay, update:
I spoke today with the fellow who hasn't been able to register his jeep. It is a '43 Willys bought restored from Olive Drab Fever. Wis DOT is refusing it for the same 'not designed for highways' which we're getting. This is not a legislated issue, rather a policy WISDOT implemented Dec., '06. I was told by this owner (he prefers to keep his name private for now) that John Varner of MVPA sent a letter yesterday to all Wis. MVPA members requesting that they all contact their representatives asap........
h2oskidds
Post by h2oskidds »
I sent e-mails to Rep. Sheridan and Sen. Robson's offices. Got a response from Rep. Sheridan's office that they will coordinate with Sen. Robson and check into it.
Also sent an e-mail to RedBull. With their fleet of Pinzgauers I thought they may have a vested interest.
Do we know how many Pinzgauer owners there are in Wisconsin?
Scooter
Post by Scooter »
I got a response from my state Rep's office.
Looks like 30 Pinz owners have gotten "the letter"
Is there any "original" documents that show the truck was made for both on and off road. The DOT seems to think that the truck was only made for off road. This may be the ticket for step one with them. The DOT is doing "more" research to determine the on or off road worthyness of the truck.
Thanks for any help we can get.
Scooter
andy
Post by andy »
I guess they think Switzerland and Austria don't have paved roads and their militaries only move on cow paths to get from point A to point B.
Keep after them, it sounds like you are making slight progress in the right direction.
A bar F
George Stauffer told me that there were 40 trucks in Wisconsin so far. I'm assuming that includes his 12. George is Swiss by nationality. Interestingly, he tells me that Off-Road operation of these trucks in Switzerland is ILLEGAL. Can anyone here verify that?
There are a lot of original Steyr documents that seem to clearly refer to 'on-road' uses and characteristics. The Operations Manual has on- and off-road driving instructions.
I'm guessing that the s**t is beginning to hit the governmental fan, thus the DMV doing more research. KEEP THE LETTERS COMING.
EuroPinz
Post by EuroPinz »
In most of the European countries it is forbiden to drive offroad which is something that the "green" political parties have been able to accomplish, simply in order to preserve nature, its wild animals and the eco system. This only happened a few years ago - but during the time the Pinzgauers were build one could drive anywhere. These are just recent laws, same type of b*******t that you're facing now in Wisconsin.
However you need to hope that DMV never gets hold of Magna Steyr as here is the response they gave me:
Regarding the situation in Wisconsin we cannot be of any assistance to the Pinzgauer owners.
The Pinzgauer was not developped for the US market and therefor do not correspond to the criteria of FMVSS
Regards,
Jacques
jpipes
Post by jpipes »
Very sad story indeed. Ironically I moved from Wisconsin to California in July of 2000. Who would have thought that Wisconsin would ban military vehicles before CA! :shock:
The really annoying thing about the above comment regarding "offroading" in Europe is that very few if anyone actually drives "offroad" anywhere. 99% of all trucks are used on some form of trail, cutback, path, scrable, route, access way, dirt road, mountain throughway, etc, etc, etc. Every route I've ever driven on has been a designated trail or route of some sort. No one takes off across the open wilds ala Paris to Dakar. :roll: It really bugs me when people claim or suggest that offroading is horribly destructive because nearly all trucks stay on some form of trail when doing their offhighway driving.
pinzwheeling
Post by pinzwheeling »
jpipes wrote:It really bugs me when people claim or suggest that offroading is horribly destructive because nearly all trucks stay on some form of trail when doing their offhighway driving.
The problem is stated above, " Nearly all the trucks". It's the 1% of the folks that go flying across private property or fields that cause many of the issues for the rest of us.
We now return to your previously started topic.
Michael
email: rosenblumm@gmail.com
