Page 6 of 7
Re: Center consoles
Posted: Thu Apr 12, 2012 12:12 am
by westernair
Recived mine yesterday, put a coat of orange peal on it and painted it OG. Thanks Mike, I really appreciate it!
Re: Center consoles
Posted: Thu Apr 12, 2012 9:05 am
by berger
westernair wrote:Recived mine yesterday, put a coat of orange peal on it and painted it OG. Thanks Mike, I really appreciate it!
I am anxiously awaiting mine!! How did you apply the "orange peal?"
Re: Center consoles
Posted: Thu Apr 12, 2012 2:57 pm
by texas pinzgauer
The name of the stuff I used isn't handy right now but it was just a textured spray material from a local hardware store or Home Depot. Note - this stuff was sort of rough to the touch so you might consider sanding it slightly before you go painting it or you'll likely lose some skin on your right elbow when off roading!
Re: Center consoles
Posted: Thu Apr 12, 2012 4:35 pm
by 4x4Pinz
while I have not used the spray stuff on the console, I have used it before. I like the texture you get from a 3/8 nap roller better than the spray on stuff. The liner is available in quart cans which should be enough to cover the console and the rollers can be had in the trim size and are fairly cheap.
Just a thought
Re: Center consoles
Posted: Thu Apr 12, 2012 10:30 pm
by westernair
I just used "spray tex" set it on medium texture. Takes 5 min to dry and then I painted it with a few coats of SAV Swiss green.
Re: Center consoles
Posted: Fri Apr 13, 2012 6:27 am
by berger
westernair wrote:I just used "spray tex" set it on medium texture. Takes 5 min to dry and then I painted it with a few coats of SAV Swiss green.
Could you take some pics?
Re: Center consoles
Posted: Fri Apr 13, 2012 11:09 am
by westernair
Re: Center consoles
Posted: Fri Apr 13, 2012 11:48 am
by texas pinzgauer
"Ribbed for extra pleasure!"
Re: Center consoles
Posted: Fri Apr 13, 2012 8:26 pm
by audiocontr
Exorcist!
Re: Center consoles
Posted: Sun Apr 15, 2012 8:23 pm
by berger
They look great! Anxiously awaiting mine!
Re: Center consoles
Posted: Thu Apr 19, 2012 7:05 pm
by berger
I got mine today...and it is VERY well made! This is so worth the money. I hit it with some rubberized spray to get the texture others have added, then I will paint it OD.
Re: Center consoles
Posted: Thu Apr 19, 2012 7:24 pm
by 4x4Pinz
harder to get a console to Canada than to get a southern neighbor into the US. glad it made it.
Re: Center consoles
Posted: Thu Apr 19, 2012 10:31 pm
by totaljoint
We have around 11 million examples that the latter isn't all that difficult.
Re: Center consoles
Posted: Sat Apr 21, 2012 11:29 am
by djw
Got mine a couple of weeks ago, thanks!
For my installation I had to significantly lower/alter the clips on the console (put the rear on the bottom after grinding a slot in the metal piece, removed the front and put a spacer/washer on the lower screw mount). Tried it first as Krylon Camo and did not like that look, then redid it with Krylon Hammered Black and I think it is a nice look and is consistent with the doghouse.
Re: Center consoles
Posted: Sat Apr 21, 2012 8:19 pm
by texas pinzgauer
Looks good!
