Wanted - Haflinger 75KPH Rear Hub Gear Set
Posted: Thu Nov 26, 2015 5:21 am
by Garrycol
Wanted Haflinger 75KPH Rear Hub Gear Set - not the full set but just the two gears (drive gear and large hub gear) for one rear hub of a Haflinger. The rear hub gears are different to the smaller front hub gears.
Garry
Re: Wanted - Haflinger 75KPH Rear Hub Gear Set
Posted: Thu Nov 26, 2015 7:32 am
Do you know what model(s) of Haflingers came with the 75km/h gears??
I think the Canadian model did but I am not sure of others that may have
Posted: Thu Nov 26, 2015 8:46 am
by Garrycol
I believe it tended to be the later models but they can be retro fitted to all.
Posted: Thu Nov 26, 2015 9:13 am
Garrycol wrote:I believe it tended to be the later models but they can be retro fitted to all.
Yes but the key is knowing which models have/had them in order to find you some
All the parts one's I have run across have been Pathfinder models and they had the 64km/h hub gears
Posted: Thu Nov 26, 2015 9:28 pm
by Garrycol
Thanks but I don't specifically know. Maybe they were not standard but an option - certainly my 73 Series 2 was fitted standard with 70kph gears.
Maybe someone with more knowledge can answer.
Garry
