Folding windshield kit
Posted: Mon Nov 30, 2015 6:14 pm
by NEWFISHER
Hello,
I did a little searching and didn't find the info and also talked with Scott at EI. He thought a member was producing the pieces in a kit type form. Anyone?
Scott can get "most" of the pieces, but I would like to buy complete from a member including the top w/shield frame to top bits.
Jon
Re: Folding windshield kit
Posted: Mon Nov 30, 2015 7:19 pm
by kdiqq
If I kit isn't available, I have access to both an Austrian (factory folding windshield) and Swiss (no folding windshield) Pinzgauer and I'd be happy to make a kit if there is enough interest. It won't be too hard.
Posted: Mon Nov 30, 2015 9:53 pm
by NEWFISHER
Thanks!
Sent you a pm
Posted: Tue Dec 01, 2015 9:15 am
I have never seen or heard of a "kit" but who knows - someone out there may have one, I just have never seen it.
Anyone else see a kit before?
Posted: Thu Dec 03, 2015 12:07 pm
by David Dunn
You guys are making a big thing out of nothing. :roll:
The Austrian truck had all the hardware to fold and a "quick release" at the windshield for the canvas. The Swiss trucks have the hinges, not the holding brackets or quick release top.
The Swiss trucks have the hinges at the bottom of the frame. The "locks" on the inside for the frame may be the same one used as the Austrian trucks ( a hinged piece) , or a solid piece of steel (Swiss Pinzes have had either type) None of the Swiss would have had the the knobs ( not big deal, use a wrench on the bolt) that held the "frame lock".
The top of the frames were different, I doubt anyone wants to pay the money for a new front canvas and hardware...On the Swiss trucks just remove the leather belts from the loops and peel the canvas and roll it up. The straps are on the roll bar for tying the canvas in place. Leave the angle piece with the loops on the frame, there is no need to remove it. The Swiss still rolled the canvas back, just didn't want the windshield folded down
Now, the only items needed are the actual brackets with the mounting plates and springs... there is nothing magical on the rest to warrant spending big money.
Back when I did have gas Pinzes, I was given a "kit"(someone had ordered the components separately and put them in a bag). Just 2 frame retaining pieces, 2 knobs and 2 hinged frame lock pieces.
Posted: Thu Dec 03, 2015 3:15 pm
by kdiqq
That's all I had planned to make.
Just a nice one-piece bracket that attached at the headlights that would both support and secure the windshield.
That way there is no need to order the brackets AND the headlight bumpers. It was going to be a pretty cheap part too. I have a few preliminary models and drawings put together, I just need to take a few measurements from a soft-top Swiss Pinz.
The only real challenge in this is just restraining the the windshield correctly. Didn't mean to make it sound like this was a huge undertaking.
Posted: Thu Dec 03, 2015 4:03 pm
by David Dunn
Just copy the Austrian bracket and bolt to the front of the truck next to the Swiss's headlamp guard, or remove the inner guard.
Just make sure you find a spring that won't let the bracket come off the windshield frame
Posted: Thu Dec 03, 2015 6:18 pm
by kdiqq
It's not exactly a clean 'bolt on' affair. The Austrian bracket is welded on, not bolted. Plus, observe the boss behind the bracket. That's where a hole would be if you removed the Swiss headlamp guards. So this would already require welding and filling a hole (which could be as simple as a bolt, admittedly)
Then you have the process of drilling additional holes for the Austrian bracket as it is also different.
Again, I'm hoping to simply this process by having a one or two piece design that just bolts on.
Just for fun, here is the cool knob you get.
That one might be worth getting just for the bling.
Posted: Fri Dec 04, 2015 12:17 am
by NEWFISHER
Would like a price on the brackets and knobs. Pm'ed you.
Posted: Fri Dec 04, 2015 5:46 am
by stiffler4444
kdiqq wrote:That's all I had planned to make.
I'm definitely interested in this setup. I, as well as others, truly appreciate your investment of time in this project.
Posted: Sat Dec 05, 2015 6:26 am
by Middlebury_Pinz
I have a complete set of these, less the body welded brackets. I don't want to sell them, but could photograph and draw them up for you guys. The body bracket could be moved inboard as long as it was parallel to the windshield frame. I might have an extra pair of the windshield "Pinz" bolts also.
Let me know,
Posted: Wed Mar 16, 2016 10:22 pm
by NEWFISHER
Sourced all of the parts I need through Haflingertech.com in the U.K. except for the inner Puch knobs and hinged inner bracket. I fabbed my own inner bracket, picked up some generic knobs from Cold War and will build the body mounts to attach the rest. I plan on incorporating a strap style lock down and a padded slip cover for the windshield when in the down position to protect from limbs and glare.
Posted: Wed Mar 16, 2016 10:26 pm
by NEWFISHER
Pic of the goods
Posted: Thu Mar 17, 2016 7:51 am
by kdiqq
Those rubberized ends are nice
Posted: Thu Mar 17, 2016 12:02 pm
kdiqq wrote:Those rubberized ends are nice
Plasti Dip, useful for re-coating the rifle mounts etc great stuff available as dip or spray, many colors available.
