VDO Tach jumping around
Posted: Fri Apr 29, 2016 9:14 pm
Okay, weird thing happened today.
I took the pinz out to set up a water catchment tank about 100 miles from my house. Going everything was very normal, did my work, took a few hours, the old girl did very good.
I filled up with some gas (fresh) and headed home. Went about 50 miles and stopped to top off from my last jerrycan (again fresh gas). Killed the engine, filled up and when I went to start the truck, it took an abnormally long time to start and did not come to life but sort of limped along until I gave it a good bit of gas. A little more smoke than usual when it started. Figured, maybe was hot, fuel in the line vaporized, who knows.
Got on the highway and noticed my tach was bouncing around like crazy, 3k-4k, sometimes up to 5k... Performance was also lacking, seemed like it wanted to go 50 mph and had not get up and go, almost like it was governed. I normally try and keep it under 60 @ 3500-3800 rpm's or so.
I drove home, not stopping, then at my exit when I had to slow down, the problem seemed to fix itself, tach was acting normal and the power seemed restored. Although speed limit is 40 in my neighborhood, it felt normal.
I know my tach is powered by my 24-12v converter, the 4500 light never came on, and this is not the first time it has happened but by far the worse one. Last time was similar but only lasted a few seconds. I am having a hard time figuring out why a 12v tach would affect performance or why the lack of power would manifest in a bouncing tach.
Does anybody have any thoughts about this?
