Update: Seat belt buckle for Pinz
W108, W109 Mercedes Benz klippan...found on ebay for $35.00. Hope this helps. Zig
Re: Update: Seat belt buckle for Pinz
They look similar, buckle a little wider and the length of 2 of them are shorter? Have you used one and can confirm they work?
Works perfect.....I only needed the passenger side and its identical to the original.
IMHO, if I care enough to use the seatbelts, which I do, I'm worth the cost of the originals: http://www.pinzgauer.com/showdetails.ph ... 111836280R
Pricey? Yes, but after 40 years it's not a bad idea to replace the whole assembly.
