Looking for Dyno in S.F. Bay area
bikmakr
Post by bikmakr »
20160821-134355-1208-HDR (Medium).pdf
(252.97 KiB) Downloaded 312 times
I'm finally approaching the end of my ITB EFI project and have worked most of the bugs out of the tune. Now I need to run some WOT draws on a dyno. Does anyone know of a shop that can rack a 712, preferably in the SF Bay area?
Re: Looking for Dyno in S.F. Bay area
I looked, called, begged. No one interested in doing pulls on anything but Ferrari's and Lamborghini's in the Bay Area :(
Ending up with John @ Outfront Motor Sports doing the pulls for me. John is the man if you want the experience and
ultimate tune job. It's a long drive to Buena Park CA but well worth it. A side trip if'n your going to Mogfest at Calico :)
What ECU you running? Might be able to at least get you in the pall park on tuning.
ron
bikmakr
Post by bikmakr »
DSCN0630 (Medium).pdf
(275.41 KiB) Downloaded 320 times
I'm running the new Megasquirt 3 PRO. It's incredibly versatile for running fully a sequential ITB system.
McCall Pinz
Post by McCall Pinz »
:shock: looking good. Nice solution to fix the unequal length intakes.
eat, sleep, Pinzgauer
You will need to remove the wheels on one of the rear axles (IIRC, I took the wheels off the middle axle). Put two lugnuts on to hold the drums in place. The drums will hang with about 1-2" clearance, if your limiting straps are intact. Outfront can only dyno one axle. They have done many Pinzis.
