6x6?
6x6?
Hope they took the advice.
- 0889.jpg (87.8 KiB) Viewed 6685 times
Re: 6x6?
WHOA! Step far far away from the welder. Judging from what I can see, The only true "welder" in this equation is the machine itself......
Re: 6x6?
I guess some folks just prefer 6 wheels?
What immediately springs to mind was a blue Ford Taurus wagon I saw up at Road America several years back with tandem axles on the rear. The two rear axles meant they needed to sacrifice the rear doors, so it was only a two-door. That one looked pretty cool, IMHO.
Re: 6x6?
I met a guy in the late 90's who had added three trailer axles (unpowered) behind the rear axle of a small pickup, cut the bed and made a four axle fender opening. They actually did a very neat job of it - looked very cool. You could put a 16' board in the bed and close the tailgate! It had no roof or rear wall to the cab, just an open air vehicle. I asked him what the biggest drawback was and he said "transitioning from level to a steep uphill driveway - it has a tendency to lift the drive axle off the ground!". With only one drive axle, I guess this would be called a "2x10".
Re: 6x6?
Much better with front wheel drive...
Re: 6x6?
I want one of those to put the Haf on, except I don't want it so long!
Anything similar, currently produced?
John
John
Re: 6x6?
I just use my Sprinter van - my hafi fits in the back with seating for five still in the front... wheels fit between the wheel wells also - I have a small electric winch with a wireless remote to pull it in - but I used to drive it into it...
Re: 6x6?
You just don't have enough Hafies yet!I want one of those to put the Haf on, except I don't want it so long!
Re: 6x6?
Can't justify a Sprinter van big enough to put a LWB in. Plus I don't have anywhere big enough to store something that long - one of the reasons I got a Haf rather than anything else like a Pinz or a C303....
It would have to double up as an everyday car.
John
John
Re: 6x6?
The mini looks interesting, wonder if you can make one with just a single rear wheel? The Merc is just to big!
I had thought of something along the lines of a wide vehicle so you get a couple of seats on either side of the Haflinger when it was loaded on from the rear vehicle. That way you can take 4 people as well when you travel with or without the Haf.
John
John
Re: 6x6?
The Mog would be basically the same speed as just driving the Haflinger
Re: 6x6?
Mini suspensions are quite weak. It would need to be completely custom and a hefty axle =)
Sourced from a rotted out trailer maybe?
Dreadnought
- Location: Pstragowa (pronounced STRONGOVA) Eastern Poland
Re: 6x6?
I remember a lot of 6 wheeled minis back in the day.......minis have a rear subframe so you just add a second subframe and extend your body......there were stronger/lower/taller cones available for rallying and that kind of thing.
