Maintenance
spoolin fool
Maintenance
Post by spoolin fool »
hey guys
What engine oil, transfer case oil, differential oil do I need to use on a 1972 710?
Re: Maintenance
I PROMISE this has been answered a bunch in the forum. All of the answers you seek are within the search function
Not trying to be difficult - I want to get you to the point that you can find the answers for most of what you will experience within the first few years of ownership
Re: Maintenance
Here is a sample that a search brought up.
I use Redline fluids so that is what I searched "Redline"
Welcome to the board!
viewtopic.php?f=12&t=7836&hilit=Redline
GadgetPhreak
Re: Maintenance
Post by GadgetPhreak »
Thanks for sharing this thread, great info for those of us new to Pinz ownership. I have searched and read for many hours but somehow missed this one. Really helpful!
spoolin fool
Re: Maintenance
thanks guys for the welcome and for sharing the thread that was very helpful.
Re: Maintenance
Use Diesel engine oil (CJ-4) or Aviation grade (depending upon how deep your wallet is).
Or Motor oil intended for classic cars.
Do NOT use Oil intended for todays gasoline fueled cars unless you want cam lobe wear and
lifter pitting. Anti-wear additives such as ZDDP are insufficient to protect high wear points in older
generation Engines with solid lifters and no rollers. Anti-wear levels were reduced due to Catalytic
converter poisoning. Unless you want lifters like the one on the right below :?
If during the winter months your rig sits for extended periods of time, toss in a can of CamGuard,
this bonds to the metal surfaces and reduces corrosion -- there are two formulas, one for ashless
aviation grade and one for ash e.g. metallic based/detergent oils (C or S designation).
Also, I would not use synthetic, even formulas with sufficient anti-wear additives.
For what it's worth I use ashless Aviation grade oil with CamGuard.
One of these days I need to post all this stuff :wink:
spoolin fool
Re: Maintenance
I will be running in high elevations 6000ft +temperatures ranging from 0-100
is there anything special oils I need to run or things I should do?
Re: Maintenance
Freezing to hot conditions use multi-viscosity; e.g. 20W50.
In a perfect world, which we aren't -- constant temperature use
a mono-grade oil, it has better "stick to the surface" properties,
thus less corrosion.
Again stick with Diesel CJ-4 or Aviation grade, pure mineral spirits.
Change oil after 3,000 miles.
Oh! Please add your location to your personal info, so's we know
where you are.
