Injectors for Beck style EFI -- up for graps
Posted: Sun Mar 26, 2017 2:42 pm
I have a set of new unused Accel 30 lb Injectors, ACC-150130, currently on Summit racing for $48 ea.
These fit the Beck style EFI setup. I bought these to replace very old Rochester injectors. Problem I
discovered is the Accel's won't fit my injector bung -- this is because I have Beck Prototype #1 which was
designed for Rochester injectors exclusively.
Since proto #1, Jim L apparently influenced Beck to standardize for the more common Bosch EV1 style
injectors, Accel conforms to the Bosch EV1 fit.
If you are interested in a set of Accel's either as a refresh or a set of spares PM me, we can deal.
Since then I found a refurbished set of Rochesters, see below.
P.S. the "quilting" around the intake manifold is insulation.
