Can anybody tell me the best coil to match up with the 123ignition I have on the way ? The outputs and resistance vary.
Flamethrower coil for 123ignition
Re: Flamethrower coil for 123ignition
I'm running the stock coil with my 123dist.
i understood from a US supplier that the 123 ignition was only available in 12 volts. How can the stock 24 volt Bosch coil work?
Thanks for any input on the subject.
Rick
Rick
I believe 50,000 (just example not sure what the volvo output is)volts coil output is the same indifferent if the system is 12v or 24v. That why guys are uing bosch superbeatle(12v) on the pinz(24v) at least thats my understanding. I think you just need a 12V source for the distributor to signal not the coil That how my TGB1111 was set up. Figured all this when I died and was getting no spark because my 24 to 12v converter died.
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
Jim provides some insight concerning coils in this thread
viewtopic.php?f=12&t=6538&hilit=jim+24v+12v+coil
