Rear Door Lock Plate 28-25-24
Posted: Wed Apr 12, 2017 3:20 pm
Has anyone removed the Rear Door Lock Plate (Group 28-25-24) for the tailgate latch?
I am needing to get a nut on a bolt that passes thru the top of the door frame for a aft closeout panel I made and it is not just simply sliding off after I remove the screws.
I did not find anything in the maintenance manual and the IPC does not give much for removal.
Can it be removed without the interior components falling out?
