Any tips on alignment?
I replaced the tie rod ends today. All went well, easy job... And the bonus of no rot surprise after removing the skid plate. I'd like to double check the alignment to ensure everything is up to spec. Does anyone know the factory specs off hand? Do I test loaded like a Pinzgauer?
63rover
Re: Any tips on alignment?
Post by 63rover »
If you counted the number of turns out and put the new ones in the same number it should be good. If you can't find the specs and it's not pulling either way you should be fine. I would guess a slight toe in of 3-4 mm max and then watch the tire wear and feel on smooth pavement.
Good luck.
Cheers, Clive
Garrycol
Post by Garrycol »
Yes before doing anything on my steering I always make it up so the new stuff lines up the same as the old - has worked to date.
Garry
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
I did the same, but who knows if it was to spec when I bought it :|
63rover
Post by 63rover »
If it's not pulling or eating tires you're good to go! After all there is very little chance of setting a speed record in a Halflinger. :shock:
Czechsix
Post by Czechsix »
From what I remember it's 0 toe, measured with two personnel in the cab.
1963 Swiss 700AP, with Black Diamond ATV tires, and a few other mods. "Always under construction".
