Ponz timing help needed
Rookie
Post by Rookie »
What is the correct degrees for timing on a 73 pinz and rpms setting
Hotzenplotz
Austria
Re: Ponz timing help needed
Post by Hotzenplotz »
it depends ....
first
ensure that the distributor rotor "clicks back" to ensure the dynamic adjustment works
if not, disassemble and grease /fix
then
set the points to 0,4 mm
do a static setting using a test-lamp
once you got the tin humming, rotate the distributor until it "sounds right" ...
Albert
Do you have points or Pertronix ?
BTW this is covered in the operators manual (around page 150 iirc) if your truck is stock and on Scotts site if Pertronix has been installed.
Rookie
Post by Rookie »
Yes sorry it does have the petronix civilian upgrade
Rookie
Post by Rookie »
Thanks guys for all the quick responses
