Steering linkage replacement
Most every part of my steering linkage is worn out. Does anyone have any suggestions for replacement parts that are not original? Anything I can find in north america that would work for tie rod ends etc? Considering having someone fabricate a new steering linkage where I can use tie rod ends for domestic trucks instead but wondering if there's an easier solution.
Re: Steering linkage replacement
Easiest solution is place an order with EI or SAV.
No tinkering necessary, should last a very long time.
My $0.02
My $0.02
Volvo Ron.rmel wrote:Easiest solution is place an order with EI or SAV.
My $0.02
Dah! Caught by the inertia of having a Pinz head wedge
Take your rods off and go to the local driveline specialists shop. They can measure your ends and likely find a match or make something close, maybe even nicer. I never replaced any before but wouldn't be surprised if a Land Rover part number matched up since the axles/brakes are British.
ProGi make good replacement rod ends, I have been running them for some years now with good results.
They also make CV boots and diff lock diaphragms.
Eric
Eric
