Where would one find an etrack rail?
Posted: Sun Jun 11, 2017 6:10 pm
by mmcc100
I've searched the usual places with no luck. Any leads?
Re: Where would one find an etrack rail?
Posted: Sun Jun 11, 2017 6:25 pm
by pcolette
Posted: Sun Jun 11, 2017 10:02 pm
Posted: Mon Jun 12, 2017 11:43 am
Just my opinion here but I would not use E-Track.
I know many have and do but the way 99% of it is installed is incorrect.
Only Scott at EI has installed it correctly from what I have seen - that means running 2 significant backing L channels and then drilling it every 2" to mount the E-Track.
viewtopic.php?f=17&t=7541&hilit=track
Having 6-8 bolts 3-4ft apart is not going to do it and is not how E-Track was designed to work.
With that said, I chose to use L-Track like they use on planes for the seats and on buses to strap down wheelchairs.
Not saying this is what you should do but it is better than mounting E-Track incorrectly!
Here are some pictures of how I had Andre install it:
Runs all around the outside edge of the side boards and is screwed into the bed every 5"
Each double seat-belt fitting has a WLL of 1,333 LBS and Break Strength of 4,000 LBS
- IMG_7184.JPG (2.02 MiB) Viewed 5324 times
Also runs around the rear where I can store extra attachment points
- IMG_7186.JPG (2.22 MiB) Viewed 5324 times
Standard use is obviously for seat belts.
The way I designed it also allows me to remove the side boards to create a flat bed pickup and still be able to reinstall the L-Track for tie down points.
- IMG_7189.JPG (1.98 MiB) Viewed 5324 times
Posted: Mon Jun 12, 2017 3:04 pm
Exactly. I used 1" square steel tubing as the structural supports for the E-Track. My usage is 98% for passenger seatbelts and only the occasional use for cargo tie-downs. I used grade 8 bolts to secure everything; no point in using cheap hardware when lives may be at stake.
Posted: Tue Jun 13, 2017 3:06 am
by VinceAtReal4x4s
Odd trivia: I recall from my fireman days at vehicle rescue classes that seatbelts were generally rated at 1200 lbs..
Gives some idea on how to rate hardware needs.
Posted: Tue Jun 13, 2017 12:46 pm
by mmcc100
Great info gents! I like the l track idea!
Posted: Wed Jun 14, 2017 3:56 pm
by whitesik
Techmogogy,
How did you anchor the L tracks? Was it bolted through before you attached the side panels or attach somehow afterwards?
Thanks!
Posted: Thu Jun 15, 2017 9:49 am
whitesik wrote:Techmogogy,
Thanks!
They are bolted through ie to remove the side boards you would need to remove the L-Track.
Edit:
More info/pics
Here you can see how they are screwed down
- IMG_8461.JPG (153.08 KiB) Viewed 5154 times
Here it is removed (small pass side rear section)
- IMG_8459.JPG (155.28 KiB) Viewed 5154 times
Nutsert and sideboard hole large enough to account for raised lip
- IMG_8460.JPG (120.33 KiB) Viewed 5154 times
Storage for extra tie downs
- IMG_8462.JPG (153.49 KiB) Viewed 5154 times
I have a drawing somewhere of how I designed it but can't find it.
Andre did the install
Posted: Fri Jun 23, 2017 10:45 am
Added info above
