Need Pinzgauer Fuel Tank and "Doghouse" engine cover
MASSIVE PINZ
Post by MASSIVE PINZ »
Hey guys, I have a 712 that needs a couple of items and I can't find them... I've tried all the normal sources, SAV, EI and etc, and no one has a good fuel tank, or a doghouse lid.
My fuel tank has "red death" and I haven't found a way that this can be addressed easily, with a known good result.
The doghouse was missing when I received the truck... Does anyone have any leads for me?
Jake Raby
www.aircooledtechnology.com
ScottD
Re: Need Pinzgauer Fuel Tank and "Doghouse" engine cover
Post by ScottD »
SAV website shows that they have doghouses in stock, new and used. Did they run out and forget to update the website?
Hotzenplotz
Austria
Post by Hotzenplotz »
fyi
the factory had a sellout
http://www.puch.at/de/ersatzteile/puch- ... pinzgauer/
offering the "turtle" for 599 Euros. might be worth contacting...
Albert
For a gas tank, give Andre a call at Fat Fab, he may be able to
build you a SS one -- no internal coating needed. And he does
the armor too boot.
I also know of at least one member who got a customer tank
built for his 710M fitted for a in-tank fuel pump. I may have
the URL to that company at home -- if your interested.
rmel wrote:For a gas tank, give Andre a call at Fat Fab, he may be able to
the armor too boot.
Andre has done a custom in-tank as well!
I have spoken with a local fuel tank fabrication company here in Phoenix. He says he can make a tank that is similar to the pinz original for just under $1k. He recommends aluminum because of the placement of the original tank. I am sure any fuel tank fabricator could make one if they had the original for a template.
Justin here in AZ has been doing gas gauge and sender modifications for the pinz. He is getting them dialed in and would be a good addition to a new tank so you could get proper fuel level readings.
On a separate note I have a stainless fuel tank and one of the corner welds is now seeping, not enough to drip just cause a dust stain. not sure if this is a stainless issue or a weld issue. I do like having the extended range of the larger tank and would choose to have one made if I had an original that was giving me troubles.
