Battery not charging -electrical doctor please
Posted: Fri Oct 27, 2017 1:04 am
We aren't getting any charge back to the battery in our 718. Can anyone help us please. I have set up links to photos below
Starting with the alternator:
- Output alternator a red (> 6qmm) cable, together with a blue and a gray-yellow cable (0.75qmm each). With a red fabric cover.
http://www.directupload.net/file/d/4888 ... 5a_jpg.htm
This red cable seems to go to the battery. The two other cables go, in my opinion, into the vehicle interior, behind the passenger seat. There I cannot locate them inside however but the collection of cables is definitely going inside.
Then a cable goes out and makes a loop back into the alternator. Goes out and back, without any component in between. Please look at the red textile-coated cable in this link.
http://www.directupload.net/file/d/4888 ... z8_jpg.htm
Then it goes into an Aluminium box underfloor by the engine on the drivers side : This box is actaully just a junction box where cables ran out to a large converter unit (which we have now removed. This included.
Three red cables, three black cables and a brown cable. These cables all go into the Alumunium box.
After opening the aluminum box, the following was in it:
http://www.directupload.net/file/d/4888 ... 83_jpg.htm
- red and black cables were simply looped through
- the brown cable as well, but with a resistor in between
This includeded three red, three black and the brown cable that went into this converter box, which is no longer present, they now go "into nothing".
I wonder where the voltage regulator and converter from AC to DC might be. I guess the three red cables are the three coils of the LiMa and thus AC. So the voltage converter / regulator probably sit externally. I've never seen the one of a Pinzgauers, know something from my old off-road motorcycles. On the "distribution plate" behind the passenger seat (vehicle is a right-hand drive) it looks like this:
(Sorry, picture wrong picture recorded)
http://www.directupload.net/file/d/4888 ... 2f_jpg.htm
Here I could imagine that it is the "Aluminium box" right above (in the picture left below) is. What has been installed by us later is only the "Digital BEP" and the reversible 60A fuse (Do not worry, no 60A go through, it is only to disconnect). Everything else was already there.
State of affairs now, the battery is no longer charged. The battery has 11.8V and it makes no difference whether the engine is running, even at increased speed, or not. The speedometer does not go anymore. Here, the owner is nothing more sure, if he perhaps already worked more ncht.
From the converter box also ran a cable forward, behind the speedometer, to a relay (cable color red), two times two cables to two control lights iin the dash and one to the negative.
Is this red cable possibly the cable that has charged the battery ? So would the converter / controller normally be contained in this box ? Inside the large box there is a red cable connected to the Mainswitch. I can not say whether there has always been something going on here.
last note : we had a charging issue once before, where we just turned on the vehicle but the charging light never went out. The following day we jump started the vehicle and went for a drive - the light went out and the battery charged. We haven't been able to reproduce this again.
Has anyone any idea what is happening here?
I've tried to find circuit diagrams for the Pinzgauers .... but none of them seem to apply.
Many thanks
Many thanks
