Do carburator shafts have seals? I do not remember seeing anything non metal in the shaft ends. Thanks.
JC
Carburetor shaft seals
boeing7873
Jerome
CRJ Driver
CRJ Driver
- Hotzenplotz
Re: Carburetor shaft seals
JC
My original carburetors were series 1 and had no seals.
I bought used series 2 carbs with identical throttle blocks, and there were seals on the shafts.
item 5 on the pic are the shaft seals part-Nr 7121085401
I refurbished both pairs last winter, and both got seals
Albert
Albert
boeing7873
Are these seals made of what material? Is it some kind of rubber or plastic? Do these fail often? Not really in the mood to remove the carbs again....
Jerome
CRJ Driver
CRJ Driver
- Hotzenplotz
I honestly have no idea what the seals are made of.
I cleaned the old ones in petrol, and they did not dissolve...
later I decided to replace all gaskets including these rings
No idea if they fail often i replaced them "just in case"
Albert
Albert
